    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. hemlock Feeling the Heat
    east coast canada
    Hello,
    I am thinking of ducting my Geyser outside to eject the cold air out of the house. My question is this - there is already existing 6" flex duct going outside, so can I reduce from the 8" duct I would need to come of of the Geyser outlet air side with no adverse effects from any back pressure I may create? Thanks.
    #1
    Helpful Sponsor Ads!
  2. GaryGary Member
    SW Montana
    Hi,
    I don't know, but that cold air that you push outside has to be made up from somewhere -- is the makeup air going to be coming from outside?
    On this house, they have summer and winter ducting for the HP water heater: http://www.builditsolar.com/Projects/WaterHeating/TC47paperAug05-1-1.pdf
    In the summer, the HP intake air comes from around the fridge, and the cool HP outlet air goes into the kitchen for cooling. In the winter they pull semi conditioned air from the crawl space and then exhaust the HP air outside.
    Gary
  3. Redbarn New Member
    SE PA
    In summer mode, I "Y" the cooler, dry air from 8" outlet of my Geyser into 2 x 6" dia pipes.
    These are insulated and transfer the cool air from the Geyser (in the basement) to the outlet registers (on the 1st floor) which are "round to rectangular".
    These outlets are certainly more restrictive than a 6" dia pipe, probably more like a 4" dia pipe.
    I have run for 2 summer periods of 7 months like this with no problems.
    This is obviously not your exact situation but in my opinion, the Geyser is darn rugged and provided the air passages are smooth without kinks or tight turns, you should be fine.
    If you are thinking of dumping a steady 6" flow of air outside, where is the replacement air coming from ?
  4. semipro Minister of Fire
    SW Virginia
    Thanks for posting this Gary. We have a HP water heater in the basement and I've considered venting warm air from the bottom of the fridge through the floor to room where the HPWH is located. I hadn't seen this article on your site despite many hours spent there.
    I've also considered venting air from our HPWH outside or elsewhere but shared Gary's concern about makeup air. I've since decided to instead try and direct all waste heat in my house to the room where the HPWH is. This includes placing electronics like routers there, and redirecting hot air from the fridge and possibly the dryer (if I can figure out how to sufficiently dry the exhaust first).
  5. hemlock Feeling the Heat
    east coast canada
    Hello,
    Thanks for the replies. The make up air would come from the HRV with the duct for outside exhaust air removed. The Geyser would play the part of the exhaust. I realize that this is a bit of a cobbled up system, but if I could pump the cold air out, it may make for a bit easier heating, and make the room a bit warmer.
  6. woodgeek Minister of Fire
    SE PA
    Not to be a negative nellie, but I don't get how this would work at all. Sounds like a big waste of time.
  7. semipro Minister of Fire
    SW Virginia
    It seems you could only possibly gain heat if the Geyser exhaust is at a lower temp than the outside ambient temp. Under those conditions I think it would work.. at least during the heating season.
  8. hemlock Feeling the Heat
    east coast canada
    Just sending the cold air outside, rather than back into the house and having to reheat it.
    Semipro - thats just it. I'd only do this during the heating season. During the warmer months, I would simply put the colder, dry air back into the house. The ducting is essentially already there. It would be fairly easy project.
  9. woodgeek Minister of Fire
    SE PA
    semipro nailed it. If the exhaust of the geyser is cooler than the interior (which it is) but warmer than the outside, then exhausting it only costs you energy (since you are sucking in even colder air somewhere else as makeup). So, it would only pay to do this a few hours per year when the outside temp was only slightly cooler than the indoor temp.
  10. semipro Minister of Fire
    SW Virginia
    Edit: Actually, heat flow in this case is also dependent upon the amount of heat the air can hold, which in this case is dependent upon water content. It is possible to "lose" heat from the house even if you're exhausting air colder than that outside if the air you're exhausting contains more water than that returning to your house via the HRV.
