Earthstove 200 R need help with this stove on how best to use it
Is this a Earth Stove C200 R fireplace insert?
I just got an earth stove c200r. Mine has a fan and it works. I believe the top opens up for when the stove gets hot and the fan turns on, the opening is not obstructed, the air can easily flow out. As on how to work it, Try this I have a manual for you If I can get it to copy on to here.
  • Colony_Hearth Manual.pdf
I would like to add that it needs to have a liner attached to it. From the manual it looks like you will need to come up with an adapter plate to do so
