Ecobee Thermostat with pellet as stage I and furnace as stage 2
hikertom
3
NH
Hello,
I recently picked up a Vistaflame (Store-brand Enviro) VF55 multi-fuel pellet stove and I want to wire it to my Ecobee Smart Si thermostat so the pellet stove is treated as stage 1 heat and the oil furnace is my stage 2 backup. The VF55 comes with it's own wired thermostat and there are two wire connections on the stove (basically it's just looking for either a complete circuit or a broken one to tell it whether to run in "hi" or "lo" mode.
Anyway, here are the connections available on my thermostat:
N/C
Y (1st stage comp)
W O/B (1st stage heat/reverse valve)
G (fan)
RC (Cool transformer)
RH (Heat transformer)
C (common)
Y2 (2nd stage comp)
W2 (2nd stage heat or aux)
It's clear to me that the W wire will be connected to the pellet stove. I am unclear on which other wire needs to be connected to the pellet stove to complete the circuit the stove is looking for to function normally with the thermostat. I have searched for this at length but have found surprisingly little about how to set it up. Your help is greatly appreciated!
Ecobee can be found at www.ecobee.com. I am really impressed with it so far.
Tom
Hi Misterpat-
Thanks for your reply. I am not sure how that would work as G controls the fan on the furnace. Does your thermostat also use G to control your fan?
I have a thermostat just for the pellet stove. I tested it with my multi-meter switched onto continuity and it beeped once the t-stat called for heat.
Hello
If you just connect a pellet stove to this T-Stat you use RH and W
Now the 2nd stage is the tricky part
My best guess would be RH and W2 if your furnace uses a millivolt T-Stat, if your Furnace is 24 volt that would be different.
N/C
Y (1st stage comp)
W O/B (1st stage heat/reverse valve) <<<< Pellet Stove
G (fan)
RH (Heat transformer) <<<< Pellet Stove
C (common)
Y2 (2nd stage comp)
Hi Tom. Did you ever get it working?
Did some research and came to the following conclusion. Can't just mix 24V central heat/AC R with a seperate millivolt R.It might actually work due to the seperate common but not sure if its safe for the stove electronics. Here is what I will be setting up next weekend:
I will be moving W to W2 to have my oil furnace as second stage and hook up a 24V relay between W and C in the basement. On the the secondary side of the relay I will connect the two wires from the pellet stove. This isolates the two circuits and should give me exactly what I need.
Will update this thread when done.
I have an Ecobee3 Lite. I am looking to run a GFI55 pellet stove as my stage one (TT) and my oil fired furnace as stage two. I have ran a common wire tapped from the transformer at the furnace. Can I use Rh for both stages, W1 and W2 with a common and not have issues with the wrong voltage being sent to the pellet stove?
