Electricians? For a boat
WellSeasoned Posted By WellSeasoned, Apr 21, 2013 at 7:53 PM
  1. WellSeasoned
    WellSeasoned
    Guest 2.
    NULL
    Boy, I screwed up bad today. I was all happy, purchasing a new boat cover from cabelas, and started the Dewinterization process on the smokercraft. I made a mistake I think reversing the ground cable for the starter. I hooked up all 4 cables, the main pos & neg, then 2 other wires to the pos side of the battery. I noticed the 1 wire getting warm, so I quick disconnected everthying, but not before the cockpit filled with a lot of smoke. Upon inspection, the wires from the ignition to a connector were fried. Plastic melted all over, wires coming off, ect. I have an electrician friend who will try and figure it out. Sucks!
  2. NW Walker
    NW Walker
    Member 2.
    NULL
    Nov 26, 2012
    88
    41
    Sorry to hear it WS. Marine wiring is what I do, if you guys can't get it sorted, hit me up and I'll try to help from here.
  3. Jags
    Jags
    Moderate Moderator 2.
    NULL
    Staff Member
    Aug 2, 2006
    17,498
    6,073
    Loc:
    Northern IL
    Just had the fun of replacing fuse block and a small handful of terminal ends on my boat. Corrosion. All terminal ends are now soldered.
  4. NW Walker
    NW Walker
    Member 2.
    NULL
    Nov 26, 2012
    88
    41
    Jags, while I understand your approach, current ABYC standards forbid soldering for terminations due to poor vibration resistance. Current practice is crimp lugs with integral heat shrink jacketing to resist corrosion. Not saying you did it wrong, it's probably way better than what you had before. Just throwing it out there for others who may be reading.
  5. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,498
    6,073
    Loc:
    Northern IL
    Good info.
    Mine is just a little fishing boat. And I didn't let the solder wick past the terminal (used to be micro mini certified), so probably not a lot of issue with brittle wire. But good to know the "proper" way.:)
  6. WellSeasoned
    WellSeasoned
    Guest 2.
    NULL
    I'll be taking the boat to my friends after work to find out if its doable. Keeping fingers crossed:oops: I'll keep everyone posted
  7. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,780
    8,583
    Loc:
    South Puget Sound, WA
    In the two yachts I helped build every connection was crimped, soldered and then marine heat shrunk. In over 20 years on salt water there have been zero electrical connection failures.
  8. basod
    basod
    Minister of Fire 2.
    NULL
    Sep 11, 2009
    937
    351
    Loc:
    Mount Cheaha Alabama
    Sounds like you hooked the ground of your ignition to the positive? with the main chassis/starter/engine ground already installed.
    Should be just the one wire that you hooked up and is most likely burned at the crimp(highest resistance) connections.
    Good idea to change the entire length of wire as a megger won't see much insulation breakdown if the boat is fiberglass - different story when everything inevitably gets wet.
  9. WellSeasoned
    WellSeasoned
    Guest 2.
    NULL
    You hit the nail on the head I think. That wire of a larger gauge got quite warm, but the smaller one all the way up under the console had a meltdown, taking other wires within the harness down with it. Ill surely know more tomorrow once we dig in.
  10. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,498
    6,073
    Loc:
    Northern IL
    Hey NW Walker - what is the goto accepted method for butt splices in a boat?
  11. NW Walker
    NW Walker
    Member 2.
    NULL
    Nov 26, 2012
    88
    41
    Depends on who is regulating the build. 46 CFR for most commercial vessel builds doesn't allow them in wire ways at all. Currently accepted practice on private boat service work is again marine tinned crimps with integral heat shrink jacketing, with the whole splice then sealed in marine heat shrink tubing.
  12. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,498
    6,073
    Loc:
    Northern IL
    Link?
  13. NW Walker
    NW Walker
    Member 2.
    NULL
    Nov 26, 2012
    88
    41
  14. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,498
    6,073
    Loc:
    Northern IL
  15. WellSeasoned
    WellSeasoned
    Guest 2.
    NULL
    Should be a simple fix. Only damaged part is the ignition wire harness. Once I can find that part, my buddy will install a decent radio. Cheers!
  16. WellSeasoned
    WellSeasoned
    Guest 2.
    NULL
    UPDATE ****
    The ignition wiring harness arrived, yamaha original part. Quick reconnect, then while we are at it, will install the new stereo and speakers. I heard that country music will bring the bass from under the logs. We'll see ;)
    Jags likes this.
