Englander 13 measurements
PunKid8888
312
South East NH
I still have not pulled the trigger yet on this stove, although I am 95% sure its the stove I want. Anyways I need a few measurements of the stove to verify it will fit in the location I want. If someone could measure the overall length and width that would be cool. Also I need the distance from the back of the stove to the flue connection. I am assuming its in the center of the stove left to right, but I cannot remember if its all the way flush at the back of the stove.
The problem I have is I am trying to place it as close as possible (left to right) to my existing chimney, but I also need to work around the ceiling joists and the roof peak. Of Course where I want the stove would put the pipe right through the peak, so i might need to use two 30degrees sections to allow some flexibility between the stove and chimney locations. Also how close can I put the stove to an Existing Brick chimney?
13-NC SPECIFICATIONS:
Dimensions: 25 1/4" W x 26" H x 14" D
Weight: 295 lbs.
Window opening: 15 3/4" x 8 1/2"
AC-G17 glass: 9 1/4" x 16 1/2"
Firebox size: 1.8 cu. ft.
Flue size ID: 6"
Approx. Flue height to top exhaust: 27 1/2"
Thanks Mike, how about flue location, is it flush with the back of the stove or is it some distance away. ( trying to figure out roughly how far fwd the stove will sit in the room)
I don't have a 13 but I know the flue collar sits forward of the rear of the stove pretty much like my 30-NC. On the 30 the centerline of the flue collar is about eight inches from the back of the heat shield.
So wait a minute, its really only 14inch deep? is that the external dimensions? I cut a piece of newspaper to the approximate size and it seams small.
yes , the dimensions i posted were of the stove itself. its an east west load unit. as far as the collar standoff , the flue collar is 3 inches from the back of the shield, or 6 inches to center from the back of the shield.
check page 6 of this manual for clearance info http://www.englanderstoves.com/manuals/13-NC.pdf
Mike does the measurement include the heat shield? I don't think it does.
It may be little but it is a mean one. :)
as far as the overall dimentions i dont think so either , but my measurements on the flue collar do include the shield, i will double check as soon as i can and if im wrong i will so post
