Hello,
Trying to install a thermostat on my 25 EP. I have the ADMH110 thermostat from Ace hardware. I'm seeing some conflicting info on where I should put the wires. The englander site says to put one wire on the G connector and one on the white. But I have also seen... put the wires on the W and the RH. Which one is right? Plus I was under the impression that with the t-stat on this model the stove is supposed to turn off and on but it doesn't turn off it stays at the low burn setting. Am I doing something wrong here?
