englander 25 pdvc black glass
86 toy Posted By 86 toy, Nov 24, 2009 at 11:14 PM
Thread Status:
  1. 86 toy
    86 toy
    Member 2.
    NULL
    Feb 5, 2009
    134
    0
    Loc:
    Mifflinville PA
    not sure if this is a normal trait for these stoves but my glass gets a black soot build up on the right side after about 2-3 hours of run time. it does it faster on higher heat settings it also seems like my fire is kind of lazy on the right side also. i have replaced my burn pot gasket as per the suggestion of englander and perfored the flame test around the door and glass to look for leaks but found nothing. am i being fussy or does this really sound like a problem?
  2. Smudge88
    Smudge88
    Member 2.
    NULL
    Sep 24, 2008
    104
    0
    Loc:
    Cedar Knolls, N.J.
    Might be pellet brand...
  3. geek
    geek
    Minister of Fire 2.
    NULL
    Feb 28, 2008
    1,470
    10
    Loc:
    Central CT
    i get the same on my 25-pdv but not after a couple hours as you mentioned, i'd say 10/12 hours or so...
  4. imacman
    imacman
    Guest 2.
    NULL
    Strange that it would be worse on high heat setting. As mentioned above, could be pellets, as I know nothing about hardwood heat pellets.
    I guess that I want to ask the usual question " when was the last COMPLETE cleaning on this stove?" ....and I don't just mean empty the burnpot & vacuum the firebox.....I mean EVERYTHING (ash traps, blowers, pipes, etc).
  5. jtakeman
    jtakeman
    Minister of Fire 2.
    NULL
    Dec 30, 2008
    13,497
    1,573
    Loc:
    Northwestern CT.
  6. geek
    geek
    Minister of Fire 2.
    NULL
    Feb 28, 2008
    1,470
    10
    Loc:
    Central CT
    ah?
    jay, you ok? LOL....
  7. jtakeman
    jtakeman
    Minister of Fire 2.
    NULL
    Dec 30, 2008
    13,497
    1,573
    Loc:
    Northwestern CT.
    What?
    macman was saying he didn't have info on these pellets.
    If I new anything about the stove I would post it, But I have not a clue about the Englanders. I will leave that for you guys.
    Sorry if I oopsed!
    Hay I am entitled to an oops or too. No?
    jay
  8. 86 toy
    86 toy
    Member 2.
    NULL
    Feb 5, 2009
    134
    0
    Loc:
    Mifflinville PA
    i forgot to mention that i have tried about 6 different brands of pellets some are worse than others but they all do it. and also this has been an issue since the stove was new back in febuary this year and i did a full cleaning about a month ago including the leaf blower trick. i have an oak installed and i bought the vent pipe kit and installed it exactly as the intructions said. it's just weird how the fire is lazy only on the right side i'll try to get a picture and post it on here so you guys can see what i'm talking about
  9. imacman
    imacman
    Guest 2.
    NULL
    Glad to hear you did the complete cleaning including w/ leafblower.
    I guess based on your 1st post that you've spoken to Mike H. or one of the factory techs about this.....have you called them back & reported what changed, if anything?
  10. Scoop
    Scoop
    New Member 2.
    NULL
    Nov 29, 2008
    190
    0
    Loc:
    Southern Ontario
    I don't have this model stove but I think black glass pretty well goes with the territory. It's easy to clean it off so don't sweat it.
  11. pelletizer
    pelletizer
    Minister of Fire 2.
    NULL
    Jul 17, 2008
    663
    12
    Loc:
    Pellet County N.H.
    These stoves do this but not as quick as you say What heat setting are you on? 1/1 2/2 3/3 etc etc
    Bottom factory preset buttons what are they at 6/4/1 is factory for mine (2008) model
    you can change the bottom settings like to 5/4/1 or 6/5/1 but that only works on heat setting 1 and 2, anything above factory default's rule 6/4/1 are you using a outside fresh air supply.
    How old is stove? when did you last clean the exhaust blower fan blades since the gum up with soot after about a ton of pellets.
    you will figure it out good luck.
  12. 86 toy
    86 toy
    Member 2.
    NULL
    Feb 5, 2009
    134
    0
    Loc:
    Mifflinville PA
    yeah i spoke with a tech and havn't called them back yet. i just posted here to see what you guys think. i'm gonna call englander back tomorrow
  13. 86 toy
    86 toy
    Member 2.
    NULL
    Feb 5, 2009
    134
    0
    Loc:
    Mifflinville PA
    stove is a 2008 model . my bottom settings were 6/4/1. i have the low settings set pretty good at 5/4/1. the burn seems to get dirty at heat setting 4 and higher
  14. yknotcarpentry
    yknotcarpentry
    New Member 2.
    NULL
    Sep 20, 2009
    142
    0
    Loc:
    s.maine
    I get the same glass problems but generally after 10 or so hours with how I normally run it , the right side is definatley more active for me , I have my stove set to 5-4-1 and mostly run it heat setting 2 blower 3.. I have noticed on higher settings it does happen faster. I have just recently cleaned it fairly well, vac'd ever thing out inside removing all plates and replacing the pot gasket. Instead of doing the leaf blower I hooked up my dust collection system from the shop, sucked out some ash but not as much as I was thinking I would get. I do vac everywhere once or twice a week, run a pellet vent brush down the vent every 2 or 3 weeks. Just got a new blower gasket so I think I may take that apart this weekend and see what I find. would love to hear the outcome.... it does clean up easy though with a damp paper towel....
  15. sydney1963
    sydney1963
    New Member 2.
    NULL
    Oct 4, 2008
    770
    0
    Loc:
    Windham Maine
    I get the same thing, just wipe with a damp paper towel and all is well.
  16. staplebox
    staplebox
    Member 2.
    NULL
    Jan 2, 2008
    211
    10
    Loc:
    Eastern CT
    I get black on the right side also. I don't think it's a problem. I use a wet paper towel.
    Not sure if it's connected but I also get more carbon buildup on the bottom right of the auger tube. Maybe the way it flows?
  17. geek
    geek
    Minister of Fire 2.
    NULL
    Feb 28, 2008
    1,470
    10
    Loc:
    Central CT
    I also get the same with the carbon buildup.
    Do you guys turn off the stove before you open the door?
    I usually do a shutdown daily and then clean the glass/burnpot, what do you guys do ?
  18. pelletizer
    pelletizer
    Minister of Fire 2.
    NULL
    Jul 17, 2008
    663
    12
    Loc:
    Pellet County N.H.
    Pretty much the same as you, shutdown daily and then clean the glass/burnpot
    Sometimes I will do 36 or 48 hour burn But that involves an occasional quick ash clean out with stove running
  19. Panhandler
    Panhandler
    Minister of Fire 2.
    NULL
    Aug 24, 2008
    606
    12
    Loc:
    WV Northern Panhandle
    Make sure air holes under wear plate, in sides of burn pot are not clogged with ash.
  20. slvrblkk
    slvrblkk
    Minister of Fire 2.
    NULL
    Feb 2, 2008
    1,317
    173
    Loc:
    Northampton, PA
    You could try bumping the middle number to 9 and give it a try. I always run my stove on 4-6/9/1. I never touch the middle number anymore.
  21. 86 toy
    86 toy
    Member 2.
    NULL
    Feb 5, 2009
    134
    0
    Loc:
    Mifflinville PA
    i do a shutdown daily to clean the glass and burnpot. but i also remove the ash from the burnpot with the stove running about every 10-12 hours to keep the flame nice
  22. 86 toy
    86 toy
    Member 2.
    NULL
    Feb 5, 2009
    134
    0
    Loc:
    Mifflinville PA
    so it seems like what i am talking about is normal operation if alot of you guys who have this stove get the same build up. i love this little stove it gets plenty hot and keeps most of my home warm with a little creative air circulation
  23. staplebox
    staplebox
    Member 2.
    NULL
    Jan 2, 2008
    211
    10
    Loc:
    Eastern CT
    Ditto
  24. Topshelf
    Topshelf
    New Member 2.
    NULL
    Nov 24, 2009
    120
    0
    Loc:
    60 Miles North of Deeetroit Michigan
    I use a dry paper towel every couple of days
    Sometimes when I do a serious cleaning I use a damp paper towel. Make sure the glas is completly cooled of it could get ugly fast.
    I get more when running mine at the low settings. Havent had to bump it up yet due to warmer weather so far.
  25. pelletizer
    pelletizer
    Minister of Fire 2.
    NULL
    Jul 17, 2008
    663
    12
    Loc:
    Pellet County N.H.
    With this weather in the low 40"s and burning Curran pellets (they burn hotter than the penningtons I used last year) the stove was baking us out of the house even on setting 1/2 and 1/1 with low burn settings at 5/4/1 so tweaked it down to 4/4/1 and still plenty of heat.
Thread Status:
