Englander 55-shpepi pellet insert over heating
Slim25
5
Whitman ma
After about four hours or so the stoves fan will shut off and can smell the stove over heating because the blower fan shuts off . Is there a reason why it shuts off it doesn't happen everytime I run the stove but am worried to run it while at work or over night the stove was built either 2010/2011
Need to know , heat range ,blower speed , settings for three lower buttons and mode your running in.
It's common for the fan motors to shut off when they overheat to protect themselves. Have you ever blown out motor windings with compressed air? They collect dust, which blocks the cooling airflow over the motor's internals.
Try the three bottom settings at I - 2-1The last one should always b 1 . that is what I am running mine at . Heat range 3 blower speed 5 . Lots of heat . What mode are you running in .
Reactions: Slim25
Not sure what you mean by mode?
No the. The motor gets blown out at least once a month
You blow out the motor daily???
Just wondering, does this stove have the same convection blower motor as the 25-pdv? If so I have had the same problem in the past.. And yes it was just the motor overheating
