i've been smelling smoke for the past few days. couldnt find it. not even with the flashlight trick. had the stove since 2006/7 around then. today i had an idea. with the stove off, i lit 3 sticks of incense, put them in the burnpot and waited. easily made every single leak highly visible.
heres the problem. my largest leak is the shaft of the combustion blower !?! theres the fasco motor, its shaft which goes into the combustion fan housing. on the end is the combustion fan. the leak is through the hole in the combustion housing where the motor shaft goes through. did something fall off/melt away? i cant silicone it because of the rotating motor shaft that goes through the hole.
the stove is useable, which it has to be because its my only source of heat. theres the pesky smoke smell. have multiple co detectors in the house, nothing registers on them but still need to fix it. what do i do?
