Enviro Windsor '03 - advice for replacing panel & wiring harness
JAHlove
6
Western Mass
Does anyone have any advice for replacing board and wiring harness for a 2003 Windsor?This is
The Board harness receptacle shows a scorching on some pins (I can post pics if that helps). Service tech has diagnosed that exhaust blower not getting power. But price to repair and cost of parts high - and this seems like a straightforward repair. I can get the parts online for a lot less. I am assuming matching wires to components is the key part, but appreciate any tips. To date, I've only had to replace ignitors and pressure tubes on this stove. Thanks in advance.
Remove power. Read instructions if any. Ground yourself to get rid of any static electricity before handling board.Take a picture of the board in place. Compare the old board with the new board to see if markings are the same. Label wires if you want. Replace wire for wire if possible.
