    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. hossthehermit Minister of Fire
    Maine, ayuh, by gorry
    We'll see what happens.............
    #1
    Helpful Sponsor Ads!
  2. CtPaul Member
    CT
    I'm in the same boat :). Just finished mine!
  3. jtakeman Minister of Fire
    Northwestern CT.
    Keep us posted on your thoughts, Hopefully you'll both see possitive gains from adding an OAK. ;)
  4. DexterDay Minister of Fire
    NE Ohio
    Beer is gonna get warmer faster.... Due to warmer register temps ;)
    Eatonpcat likes this.
  5. 343amc Feeling the Heat
    West Michigan
    I'm thinking I need to insulate my OAK. It's starting to drip on the floor. Guess that means its working.
  6. Gary Gileau Member
    Griswold CT
    I didn't see or feel a big difference but my common sense tells me that all the cubic feet of air that goes out the vent is now in my living room keeping me warmer
    343amc and DexterDay like this.
  7. hossthehermit Minister of Fire
    Temps in the 40s , even overnight, makes it hard to get much of a feel for any possible effect, should be able to tell more end of the week.
  8. Eatonpcat Minister of Fire
    Eaton Township, Ohio
    If your beer is getting warm...You ain't drinkin' fast enough!!:cool:
  9. hossthehermit Minister of Fire
    Gotta say, really does feel quite a bit warmer in the cellar today, down around 0 outside this morning, 14 this afternoon, seems a lot more comfortable down there than in other cold snaps over the years. At this point, gotta give it a ::DT+
    jtakeman likes this.
  10. ChandlerR Feeling the Heat
    Hampton, NH
    My wife and I were talking about OAK's. I decided to try something. I pulled the OAK from the wall thimble and boy could you feel the cold air pouring into the house! I stuck a rag in the hole and cracked the sliding door in the room with the stove. A definite breeze came in. Hooked the OAK back up (after removing the rag!) and cracked the door open again. No breeze. That was impressive. These stoves use lots of air! Wife was impressed. She asked where the stove would be getting its air if it didn't have an OAK and I said anywhere it could. Cool experiment. (literally).
    heat seeker and DemonGT like this.
  11. hossthehermit Minister of Fire
    Ayuh, haven't done it before, 'cuz it's kinda a long run for the pipe, had to cut a hole in the sill plate to run out, cap it off, gonna hafta watch snow line, yaddayadda........
  12. kellyrnh New Member
    Southern NH
    Just finished installing ours as well. Actually pretty much a fresh install - we moved it from the basement (without OAK) to our living room (with). I can already see a difference - in both heating the upstairs better which is obvious, plus the stove seems to be running nice & hot while using less pellets. Pretty excited to see how long we can go before seeing the oil man again :)
  13. Harvey Schneider Feeling the Heat
    Southbury, CT
    But it's so good to have a clean mind. It helps me think clearly.
  14. jtakeman Minister of Fire
    Northwestern CT.
    Nah, We're just cheap!
  15. DneprDave Member
    Western WA
    The dog door eight feet from my stove is my OAK.
    I have a yellow lab, so the dog door is a big one! I can see a little bit of light all around it.
    Dave
    Eatonpcat and CtPaul like this.
  16. Harvey Schneider Feeling the Heat
    Southbury, CT
    Now imagine 60 CFM of air coming in through that door. If the door is 18" wide by 30" tall, that's a 16 foot long column of air entering every minute.
  17. moey Feeling the Heat
    Southern Maine
    Hooked up my oak yesterday. We shall see I'm hoping its not so drafty by my front door. Can't tell if its burning any better as I gave the stove a complete cleaning and LBT at the same time.
    I had a huge breeze coming in from the oak I could not believe how much came in. I cut the whole last week and had a towel stuffed in it, so I do think the house pressure was a issue before it.
    DexterDay likes this.
  18. DexterDay Minister of Fire
    NE Ohio
    Go put your hand, an incense stick, cigg, or cigar in front of the OAK intake with that Quad running....
    Some say because Quads are NOT a sealed OAK, that they do not work. Well I say its HOGWASH. :) Mine worked awesome before I sealed it up (factory form), then i applied High temp silicone and foil tape to seal it up as best I could.
    OAK's work. . . :cool:
  19. moey Feeling the Heat
    Southern Maine
    I sealed the base with clear silicone as well as the packaging holes in the bottom with high temp silicone. Need to seal the burn chamber still theres some cracks there. I think its making a difference Ill know tomorrow as its supposed to be close to 0 tonight. BTW thanks for your pictures on the classic bay oak you have it came in handy. I ended up using a exhaust manifold flange and one of Duravent OAK kits.
  20. DneprDave Member
    Western WA
    Not really, because there's a door in that hole. I have a 1/16" crack around the edge of that door. Yeah, there's a draft coming through that crack, but the porch is quite toasty. Even without the dog door, I'm sure that the porch is far from air tight, it is a porch after all!
    I figure that I saved $300 in heating oil last year by putting a pellet stove on the enclosed porch.
    Dave
  21. moey Feeling the Heat
    Southern Maine
    Well I must say I give my OAK a thumbs up after last night it got to -6F. Much fewer cold spots in the house. The burn seemed the same but I no longer have a cold spot right at my front door.
    CtPaul likes this.
  22. Harvey Schneider Feeling the Heat
    Southbury, CT
    It's good that you're happy with the OAK. The fact that you had a cold spot at the front door is an indication that the seals on your door may be leaking.
  23. CtPaul Member
    CT
    I
    I agree...i'm going to really look/feel around tonight
    Btw I just order some new door seal yesterday for my doors
