    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. sailor61 Burning Hunk
    Warwick, RI
    It took years but the Fireview (bought for a prior house etc) is installed, the old hearth is gone, front of the fireplace has been rebuilt, new stainless liner in the flue... Tonight is the first secondary burn ......OMG the heat this thing puts out ! Den ( 18 by 19) is at 84, 4 season (12 by 15) porch opened up and in the 70s, fans blowing heat into other end of the house... And it's 5 above outside. I can't say enough good about the customer support from both Woodstock and Rockford Chimney.....highly rec both. They run their businesses the way things used to be....helpful, pleasant,patient, knowledgable, outstanding quality. I'll post some install pictures in the next couple days.
    #1
    Helpful Sponsor Ads!
  2. rideau Minister of Fire
    southern ontario
    Welcome.
    I know you'll get great comfort from that marvelous, reliable stove for years to come.
  3. weatherguy Minister of Fire
    Central Mass
    Good night to test it too, if it keeps you warm tonight, your golden
    PapaDave likes this.
  4. Cross Cut Saw Feeling the Heat
    Nice, you're going to love burning that stove!
  5. charly Minister of Fire
    Schoharie, NY
    Life just got easier,,,you'll find the Fireview is a pleasure to run.....congratulations on getting your new stove up and running! Yes the folks at Woodstock are 100%.
    Backwoods Savage likes this.
  6. Backwoods Savage Minister of Fire
    Michigan
    Great! You'll love this stove so long as you feed it good fuel. And you are right on about Woodstock.
    One thing you might try though and have great luck with is to not blow the heat to the other end of the house. Sounds crazy huh? Instead, try using a small desktop fan (not pedestal) sitting in a doorway or hallway. Use the lowest speed setting. Then blow the air toward the stove room. Doing it this way will actually move more of that warm air to the other rooms because it is easier to move cool air into the warm than to move the warm into the cool. Give it a try!
    Berner likes this.
  7. sailor61 Burning Hunk
    Warwick, RI
    I'll give that a try. It should allow me to put the fan in the hall by the bedrooms rather than in the space of the house I use all the time. House is a ranch and the FV is in a good sized den that is an addition on the back of the house so moving the heat is a challenge.
  8. Machria Minister of Fire
    Brookhaven, Long Island
    Get some pics man! Congrats, I'm 5 weeks into my "new" Woodstock PH, and love it more everyday.
    That fan blowing in trick works great. My stove is on my 2nd floor (upside down house), so the challenge is getting heat down stairs. I have put a small 6" clip on desk fan from Wallymart for $10 on my staircase pointing up to the stove room. It draws lots of cold air from downstairs up, which pulls warm air down.
  9. bad69bird New Member
    New London Pa
    I am in the exact same situtation. but my addition is down a long hallway lined with closets off of my rancher
  10. Backwoods Savage Minister of Fire
    Michigan
    Don't worry about the long hallway. Just sit a fan in the hallway, close to where it starts. Blow the cool air toward the stove room and the rear rooms will warm up quite a bit.
    HDRock likes this.
  11. HDRock Minister of Fire
    Grand Blanc, Mi
    I have a long hallway also, Blowing the cool air toward the stove room in a long hallway works very, very well, the warm air above, flows through the hall like a big heat duct.
    This small fan , I got at Manards, does the job very well , and is inexpensive, I run it on low.
    Honeywell Table Air Circulator Fan
    Sku: 6211300
    Model: HT-900
    $16.99
