Fire brick lined?
Mk1390
8
Michigan
I am currently building and outdoor wood stove the fire box is a 500 gallon propane tank that is 5/16 thick should I line the bottom as sides in fire brick or sand or should I just let it burn
Brick it. If there's water on the other side of the steel, the direct-contact firebox wall is a recipe for a lot of creosote. More evolved burners now provide a fully-insulated section to burn off the volatiles (would-be creosote) followed by heat exchange sections to get the heat into the water. Not only does it burn cleaner, you get more heat because you are burning more of what comes out of the wood...
You can buy a bag of it and form it to what you want. Bricks are 3.50 ea. here. Seems like a lot and then you get spaces between.
