brenndatomu
Yes, both PSC (permanent split capacitor) motors most likely...almost all wood furnaces are.I have to believe the distribution blowers are very similar between the 2 furnaces.
Man, I hate to be debby downer, but I really think you are wasting your time speed controlling this furnace. Varying your blower speed will not change how it burns the wood. You are putting the cart before the horse, IMO.
Yep no loss there...I can use this setup on the Tundra right? [emoji41]
Probably true...but can't go anywhere but up from here, right?!Man, I hate to be debby downer, but I really think you are wasting your time speed controlling this furnace. Varying your blower speed will not change how it burns the wood. You are putting the cart before the horse, IMO.
I don’t have a POT on my speed controller and it works fine. It has been sitting on my bench collecting dust.Did you also order the ICM? If so you will need a 5k pot to adjust the temp range on your speed controller
Everybodys setup will be a little different...I had one furnace I put the ICM on, just used a 2k resistor on the temp sensor...perfect. Had a 1.2k resistor on my Tundra...having the pot is nice to dial things in with though...don't really cost much more than getting a resistor either (because you have to order resistors in quantity's usually)I don’t have a POT on my speed controller and it works fine. It has been sitting on my bench collecting dust.
Found the third difference between the Caddy and the Tundra. My Caddy has a 1/3 HP A.O. Smith motor on it vs the 1/4 HP on the Tundra. It is the same speed too.On the tundra it's a 1/4hp 1075rpm/4 speed
It might not do anything to it...they are apparently engineered to withstand explosions...all day, every day!Thinking about setting the SF1000(FC1000) out in the woods with 20#-25# of tannerite this spring when it warms up. Then I’ll ship it back with a note that the reengineering was successful but I have to charge for the plans fir the modifications.
BYOB, I’ll supply the big boom...
I think you will find that almost everybody here uses the Dwyer Mark II model 25...about the most bang for the buck thats out there, reliable tooHas anyone ever use this draft gauge? Just trying to compare current measurements using a different tool.
https://www.supplyhouse.com/Bachara...rICh0FWQaWEAQYASABEgILovD_BwE#reviews-content
What are you trying to accomplish? The timer closes the circuit when timing...Would like to start with just the timer connected. Do I just connect the 2 wires on the back of the timer to the 2 post for the thermostat to close the circuit?
OK, yeah then the tstat wires go on the timer terminals. You are just replacing the tstat with a timer basically...or you could wire it "in parallel" with the tstat...then you could use one, or the other...I am assuming in my case the timer would kick on the draft blower for X minutes.
Yes, but he said he wanted to just start out with the timer...Didn't you have your timer in parallel with your mypin to only allow it to reach a specific temperature then the mypin would kill the connection and close the damper... only later if the temp falls below your set point did it reopen only while the timer is activated? Ultimately setting a high limit temp for your flue on startup?
But like you said could always have it in line with a thermostat to control when it calls for heat aswell.
Told ya!Son of a B! The end of the government shut down came first!
