    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. brandon1 New Member
    western man
    I have a whitfield advantage peelet stove. As of late it has been burning a lazy flame on heat setting number 1, often leading to the flame going out. I have given the stove a good cleaning, removesd ash trap baffles etc. I also turned up the auger speed. I have also noticed the glass is very dirty and much harder to clean then it usuall is. Any suggestions?
    #1
    Helpful Sponsor Ads!
  2. CygnusX1 Feeling the Heat
    Central MA
    Try adjusting your air damper. It seems like you don't have enough airflow into the stove.
  3. brandon1 New Member
    western man
    i have tried that and it doesn't seem to help.
  4. pegdot New Member
    Upstate, SC
    Have you checked you vent pipe lately? Could be partially clogged.
  5. brandon1 New Member
    western man
    i cleaned it out, but didn't clean out where it comes out of the stove. There is also a 45 a few inches away from where it attaches to the stove. Good suggestion!
  6. brandon1 New Member
    western man
    I also noticed that one of the ash trap vents were capped off. Is this normal? Should they both be open?
  7. stoveguy13 Minister of Fire
    CT
    you may want to try cleaning all the way to the exhaust blower and the blower housing as well.
Thread Status:
