Fingerlakes Fireplace
Burning Hunk
how does your pilot look? Send me a picture of your pilot.Ok I check the voltage with sparking and at 2.5 setting it is at 1 and at 0.5 meter setting it is at 2 and when sparking goes off than drops to zero.
Its how I would do it. Its a small amount of gas. You have a service shut off right in the valve area? Just to see if gas does come out of it. Or slightly loosen it and spray some soapy water on it.Than no gas coming out at Pilot.Now prepilot how do I check that.The tubing going from gas valve to pilot is connected to gas valve on one end and threaded in to the valve.If I unthread it from the gas valve and check whether gas is coming out.I s this a safe way to check.
Folks I fixed it.I forgot to put one connection under the gas valve which I changed and once I did it, fireplace fired up.I am sending the pictures of gas fireplace showing red gas valve in off position.Slso sending pictures of outside house gas line and meter.
Hello! I was following this forum because I have a similar issue - I have an Astria Aries Direct Vent fireplace. The spark ignitor sparks when I turn on the switch, but the pilot doesn't light. Also, no smells of gas anywhere. I was also suspecting a gas valve problem. It appears I have the same valve as the person in the forum (pic attached). When I removed the orange wire and checked the voltage across the line when the spark ignitor was on, I got erratic readings bouncing between 1.3 - 4 V DC and it went to zero when the ignitor stopped sparking. When I had the orange wire plugged in, I measured at the metal where the orange wire connects and on the base of the fireplace and got voltage readings bouncing between 3 - 29 V DC when the ignitor was sparking and going to zero when it stopped. Have I measured the voltage correctly? Are these the readings I should expect? What other diagnostics would you recommend?Leave the wire attached. You should be able to get your probe onto metal. Set meter for 2vdc. You will see an initial voltage iirc of 1.5ish, then drop down to a lower maintenance voltage .400 volt ish...
