    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    HearthNet Webmaster, I'd like to put a wood-burning insert in my fireplace. Using your site and assistance, I have the flue size problem solved. Now a new problem has arisen. My mantle is only about 4 1/2 feet off the floor. The stoves I've seen all have a minimum stove-to-mantle distance that is significantly larger than my fireplace allows. Am I misreading the specs, is there a work-around, or is a stove just not an option for this fireplace?
    Answer:
    Many stoves can use a mantel shield, which serves as a deflector of heat. These can be purchased or made on the job (by the installer) and painted to match the stove. They could cut the required clearance to the mantel in 1/2.
    They are usually made of sheet metal, bent in a brake, and painted.
    #1
    Helpful Sponsor Ads!
Thread Status:
