First Post in the Boiler Room
lukem
3,668
Indiana
Hi All,
First post over here in the boiler room. I've done some forum searching but haven't really come up with what I'm looking for.
First of all, I'm a total boiler novice. I understand that wood makes fire, fire heats water, water heats house. That's about it.
Here's the reason I'm posting. I have a vintage 1960's propane boiler in my house feeding radiant baseboard panels. Boiler is in working order, panels work, no leaks, etc. It is very capable of overheating the house (previous older couple living here kept the stat on 78*) so I have no concerns with sizing. HVAC friend says I should have no issue with them going "bad".
I don't think I need to go into detail about how expensive the propane boiler is to operate. I'm offsetting it considerably with a wood stove. Due to the layout of our house, heating with a stove is less than ideal in terms of heat distribution (long ranch house, closed floor plan).
Now I'm starting to think if I'm going to do all the work of heating with wood, I might as well have an even heat and a boiler would be a good option.
Ideally I would:
1.) Keep the old boiler for backup heat just in case we are out of town, boiler fails, whatever.
2.) Tie in the new outdoor boiler to the existing radiant heat system
3.) Tie in the new outdoor boiler to DHW and keep the current propane water heater for non-burning months
4.) Heat my shop with a ductless forced air setup
I have room for storage inside.
I guess my questions are:
1.) House + semi-finished basement = 3,400 sq ft. Shop is poorly insulated and ~1000sq ft...plan to insulated sometime....only would heat 2 days a week at most. What size boiler would I need?
2.) What is the best way to tie into the existing forced hot water system?
3.) How much storage would I need?
4.) I would like to do as much of the installation myself as possible. I'm sure it's harder than an oil change and easier than rocket surgery. I have plumbing and carpentry skills but am not much for electrical. How hard would this be to put in myself.
5.) What am I NOT thinking about?
reply to the very last question
----> Junking the old propane boiler and replacing it with a modern condensing propane fired boiler with primary/secondary piping and additional insulation with zone controls so you can put the heat where YOU want it.
Think conservation -- not conversion
Unless the wood you can get for the next 15 years if "Free" and free wood is certainly not free.
I got a quote on upgrading the boiler. It was a lot. More than I would ever save on the increased efficiency. No ROI there.
Firewood is not a concern. I can get all I want for free and enjoy processing it.
What size is your existing Boiler?
We know that it will heat the house with a bit to spare, with a guess ion its efficiency you would then know the max to heat the house.
Tricky bit would be adding the shop.
Just a thought but unless you want to heat the shop at the same time any new boiler is heating the house in the worst conditions then you could just round up the House boiler and you would be there or there about. If at some point you want to heat the shop when the House is pulling max load then probably the cheapest option is to insulate the shop rather than oversize the Boiler.
The Garn site has some spreadsheets to work out costs and rate of return etc.
Old boiler is 200K BTU and 50% efficiency is probably realistic.
It sounds like your existing boiler is oversized maybe by as much as 50%. You should first try and get a realistic btu load for what you are heating.
If you're going to keep running that old boiler, I would suggest at the very least a Intellicon HW+ which should save you 20% running the cast iron boiler. Also look at the supply temperature, I worked on one recently that was turned up to 210. Some people think more is always better ( hence oversized boilers) If you can "tame" it a little, you can bring down the operating cost. A tekmar 260 is even better than the HW+, but also more expensive.
As for the rest, keep reading and keep asking questions.
Welcome to the Boiler Room, Virgin. Here, other people like to spend your money :) .
"don't just buy a solid fuel hydronic, get a new fossil one too . . .:
Anyway, you prolly won't use the fossil that much once you have wood up and running. And obviously you are used to the rigors of wood.
My idea would be to get the wood fired hydronic first. Then save up some casholla and put in-floor radient in. The save up more and do storage so as to capitalize on lower water temp needs.
At that point you'll be better able to decide if you want to replace the fossil fired boiler.
But wad I know?
Exactly. I know the boiler I have sucks and is probably too big. I don't need advice on it. I would like some feedback on my questions above. Please consider this a friendly redirect.
OK, here goes,
1. You need an accurate heat loss, to determine what you need. If you install storage you can oversize your boiler. Without storage, except on the coldest day your boiler will idle a lot which is ng.
2. Piping should probably primary secondary with your current boiler, not piped so that the hot water from your wood efforts are running through your lp boiler.
read up on primary/ secondary piping. I have used Caleffi hydro separators to accomplish this on several jobs- very nice, plus air separation, and a sediment drain.
3. How much storage can you afford? WAG 1000- 1500 gallons. Pressurized is easier than non in a lot of respects, but you'll need a big expansion tank
Does this help?
200k?!? Would that be Barrow, Indiana?
You can get a pretty good guestimate of your heat loss by figuring that boiler puts out 100-150k btu and then go down there and time it for a little while when you get a cold night, like tonight. If it runs 20% of the time at 0 outside temp and that's your design temp then that gives you a pretty good place to start.
Obviously, if you want to burn wood you don't want to listen to how much sense it makes to get an efficient gas system instead, but it might. You may still want to think about weatherizing and insulating the house, so the wood cutting is more of a hobby and less of a second job. If the basement is insulated and if the existing boiler is closed off from the chimney, then you'd have less loss from the existing boiler, and may not even bother redoing that piping and controls.
Seriously 200k in a ranch in Indiana? that's oversized for most of the Victorians I see with any kind of air sealing.
I know the boiler is oversized but don't have a good idea of how oversized. I'll take your advice into consideration about observing the run time on the coldest nights.
For some additional background info. The boiler is original to the 1960 house. Since the boiler was installed the basement has been partially insulated, insulation added to the attic, and all new windows (and there are several LARGE windows). The house is pretty tight now. I need to do some additional insulating in the attic but have some other remodeling projects I need to get done before I can do that (to avoid rework).
Observing the boiler run on a cold night is a great metric to observe. You can also do a quick calculation of how many feet of baseboard heat that you have. Typically new baseboard gives you about 550-600 Btu/hr/ft. Then you can figure out about how many Btu's you system can put out. Don't forget about domestic hot water, if you have that running off your propane boiler. If you are considering storage, the heat calculation is not as important, in fact it is better to go a little lager than required and more convenient for you. Just make sure the storage is sized for the wood boiler.
Contractors tend to oversize Boiler, even now.
It would not have been that efficient 50 years ago and with age a lot more so.
My guess is that the actual peak load, with insulation improvements, is less than 100,000Btu's
Baseboard usually require very high temperatures to get its rated output, higher than a wood system may prefer.
Current boiler runs up to 140* most of the time in short bursts, but will go to 180* under heavy load. What temp would wood system prefer?
I reread the quote for LP boiler replacement and it was spec'd at 120K input BTU per manual J calculation.
Huh??
I've heard anecdotal evidence :smirk: that wood-fired hydronics are more efficient at 170 than 180, but my experience doesn't substantiate that.
You run water through your baseboards that is over 200 :eek:hh: ??
If the guy did a Manaual J Calc you are at least heading in the right direction.
Find out what the Boiler efficiency rating is to see his view on net usage.
(If I ran 200 it would be steam heating)
Lukem,
Here is what I did. I installed a wood boiler in my garage (75' away) and ran a loop from there to a plate heat exchanger next to my propane boiler. This isolates my wood system so that if I need to shut it down the house is not without heat. Then I ran a loop through the propane boiler to the heat exchanger with 3 valves. When the 2 valves are opened and the one on the boiler shut the propane has to circulate through the heat exchanger. I just turn down the propane and let the wood carry the load. This works for me because I have 5 zones and a hot water maker. I am running 3 pumps on my wood boiler, 1 circulates through the boiler, 1 circulates the loop, and on is for a mixing loop at the boiler so that cold water does not shock my boiler. My propane boiler runs 2 pumps for circulation through my zones.
A couple of qualifiers. I am a carpenter, not a plumber. I understand this system but it is about at my limit. I do not have storage. I do not have a power failure back-up yet, working on it. I do have a dump zone loop in the garage and a generator sitting near the wood boiler. I have had to shovel out hot coals in Jan when the power failed. Boilers are a learning experience, 3rd year running this system and I am starting to get it right.
Doug
Works out to about 110K output BTU. This doesn't include my shop. No clue how many BTUS that would take. Moderately insulated 900 sq ft, heated sparingly.
djblech said:
Lukem,
Doug
This sounds like what I'm looking to do. I only have one zone inside the house with one circulation pump. I'm thinking I would need to have (based on no relevant knowledge or experience...please correct me where I'm wrong):
1.) Plate exchanger at DHW
2.) Plate exchanger at propane boiler (no idea how to plumb it into the existing lines)
3.) Circulation pump for loop from boiler, through plate exchangers, returning to boiler.
4.) Radiator in shop
5.) Circulation pump for loop from boiler, through radiator, returning to boiler.
6.) Thermostat in shop to control fan/air handler for radiator.
7.) Loop from shop radiator to boiler < 25'.
8.) Loop from house to boiler ~100'
9.) Control panel?
Where I'm still sketchy is how to cycle the water through the house radiators. Right now I have a very simple system where one thermostat lights boiler and turns circulator pump on...they always run pretty much together. I would assume I'd need a control panel of some sort to work in unison with the boiler (keeps propane from firing but still runs circulator). I want the propane to be an automatic backup...no intervention required.
Alright guys...where am I off?
