They are good old stoves dont get me wrong. If you need allot of btus right away they are great. But when people shut them back hard to get lower heatoutput and longer burns they make a huge mess of the chimney. For their day they were pretty good stoves. But even then there were more efficent stoves.Thanks for your participation and feedback, bholler!
I don't have a new stove to compare it to. But I know that my Fisher burns less wood with the angled baffle plate I put in it than it does without the baffle plate. The baffle plate makes a huge difference. I can also see where a double door Fisher would be less efficient than a single door Fisher.
Yes no matter what stove it is you need to know how to run it. Even the best stove can make a mess out of a chimney if not operated correctly. But modern stoves can keep the chimney much cleaner without dumping as much heat out the chimneyI friend of mine told me that he has to clean his chimney three times a year, and he uses a newer stove. He and I both use a proper class A insulated chimney but I'm guessing he burns wood that isn't properly seasoned. I season my own wood and I clean my chimney once a year. I noticed a lot more smoke from my chimney before I put the baffle plate in. We burn wood 8 months a year in northern NY, but 1-2 months is just a morning burn to take the chill off the house, during late spring and early fall. But for 5-6 months straight our stove fire never goes out. I season maple for at least 18 months, and pine for 2 years before I burn it. Ash is ready to burn one year after I cut it down.
I've learned a lot on this forum from guys like you, coaly and many others that have decades of experience with burning wood and coal in a variety of stoves and heaters. I appreciate the different views and opinions, and I approach everything with an open mind.
I have never heard of using cardboard. I always use a dollar bill if it slides out easily you need gasket. Cardboard is way to thickMy apologies, I forgot you have a double door stove. Place the cardboard along/thru the top of the right side door, close to where the doors come together. Latch the right side door and try to pull the cardboard upwards out of the top of the door channel.
You are testing the seal between the door and the channel iron on the front facing of the stove. Not the gap between the two doors.
Cereal box is still way to thickThanks bholler. I've read about using either one. But due to lack of personal experience I'll go along with the dollar bill test over cardboard. I figured cereal box cardboard, not corrugated cardboard.
