O
oldspark
Guest
In one of the recent posts about flue size a person mentioned he thought the lower flue temps of the EPA stove was part of the problem with drafting on the new stoves, I was under the assumption you tried to keep the flue temp in the burn zone with or without a new type stove, I understand that overnight it will drop but when you are tending the fire during the day do you keep it in the burn zone on your stack temp. A lower stack temp will cause creasote problems no matter what kind of stove you have correct?
