for all you mechanics and DIY types! funy!
rowerwet
The Handyman's Dictionary:
SNAP-RING PLIER: Special pliers used to propel
snap-rings from the part you
are working on to the farthest, darkest, spider
inhabited recesses of the
garage .
DRILL PRESS: A tall upright machine useful for
suddenly snatching flat metal
bar stock out of your hands so that it smacks you
in the chest and flings
your beer across the room, denting your
freshly-painted vintage car (or boat
or airplane) which you had carefully parked in the
corner of the shop (or
hangar) where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws
them somewhere under the
workbench at the speed of light. Also removes
fingerprints and hard-earned
calluses from fingers in about the time it takes
you to say, 'Oh sh--....'
ELECTRIC HAND DRILL: Normally used for spinning
pop rivets in their holes
until you die of old age.
SKILL SAW: A portable cutting tool used to make
studs too short.
PLIERS: Used to round off bolt heads. Sometimes
used in the creation of
blood blisters.
CRESCENT WRENCH: Used to prepare a bolt head for
the application of pliers.
BELT SANDER An electric sanding tool commonly used
to convert minor touch-up
jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on
the Ouija board principle
It transforms human energy into a crooked,
unpredictable motion, and the
more you attempt to influence its course, the more
dismal your future
becomes.
VISE-GRIPS: Generally used after pliers to
completely round-off bolt heads.
If nothing else is available, they can also be
used to transfer intense
welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to
prolong the conduction of
intense welding heat to the palm of your hand.
ACETYLENE TORCH: Used almost entirely for igniting
various flammable objects
in your shop. Also handy for igniting the grease
inside the wheel hub out of
which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly
used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an
automobile to the ground after
you have installed your new brake shoes, trapping
the jack handle firmly
under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering
an automobile upward off
of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool, ten times
harder than any known
drill bit, that snaps neatly off in bolt holes
thereby ending any possible
future use.
BAND SAW: A large stationary power saw primarily
used by most shops to cut
good aluminum sheet into smaller pieces that more
easily fit into the trash
can after you cut on the inside of the line
instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the
maximum tensile strength of
everything you forgot to disconnect from the
engine being removed.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large
pry bar that inexplicably
has an accurately machined screwdriver tip on the
end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the
vacuum seals under lids or
for opening old-style paper-and-tin oil cans and
splashing oil on your shirt
. It can also be used, as the name implies, to
strip out Phillips screw
heads.
STRAIGHT SCREWDRIVER: A tool for opening paint
cans. Sometimes used to
convert common slotted screws into non-removable
screws.
PRY BAR: A tool used to crumple the metal
surrounding that clip or bracket
you needed to remove in order to replace a 50 cent
part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war,
the hammer nowadays is used
as a kind of divining rod to locate the most
expensive parts adjacent the
object you are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through
cardboard shipping cartons
delivered to your front door . Works particularly
well on the contents of
the carton such as seats, collector vinyl records,
caustic/flammable/difficult to clean up liquids in
plastic bottles,
collector magazines, refund checks, and rubber or
plastic parts. Especially
useful for slicing the work clothes of the person
using the knife or anyone
standing next to that person.
GOD-D*MM*T TOOL: Any tool that you grab and throw
across the garage while
yelling 'GOD-D*MM*T' at the top of your lungs. It
is also, most often, the
next tool that you will need.
The only tool I could see missing was the pneumatic nail gun, any more?
Many thanks. A great way to start the day. :lol:
Ed
HOT AIR GUN: Used to start trim on fire while trying to strip the paint from it.
BOX END WRENCH: Used to strip the flesh off of knuckles. Sometimes the GOD-D*MM*T tool
PIPE WRENCH: Used to start water flowing where there wasn't any water before, i.e. bathroom floor, kitchen floor etc.
Thanks for the laugh rowerwet.
the tool that you use to propel nails into your boss's head while practicing your aim on cans! "wach the movie Happy Gillmore" Hillarious!!!
A couple of other additions -
Spray Paint Can - Device for applying small spots of paint to any valuable / hard to clean item within 20 feet of use. Works especially well on eyeglasses.
Bungie Cord - Elastic device used for embedding hooks into flesh, and / or putting dents into car bodies.
Gooserider
Flashlight- a handy convienent sized device for the storage of dead batteries, the perfect object to trip over after fumbling it off the shelf during a power faiure. also a perfect hammer or club when it is one of those big aluminum ones. (excellent for jackin deer)
smoke detector- see flashlight, this one is stored on the ceiling so you can't trip over it, unless you stole the batteries for your radio controlled car. (I know the firefighters on here won't like that one) realy does radio shack think I will replace my batteries 4 times a year? they run the replace your batteries because of on daylight savings, off daylight savings, 4th of july, and recently I heard either Christmas or new years in the commercial. I gues if it saves one life it is worth it.
Impact gun/ exhaust cutter- the perfect tool for removing all the loose rust on the bottom of your car. most noticable when not wearing saftey glasses.
saftey glasses- those foggy scratched plastic eye coverings that reduce you to working by feel while directing any stray chips into your eyes.
grease gun:used to apply grease around the outside of hard to reach fittings and G#D tool when you get an air pocket when you finally get the coupler on the fitting!
Air ratchet - Tool specifically designed to tighten that nut up and then slam your fist into the nearest sharp piece of metal.
How bad is it to have experienced almost all those descriptions?
Just curious, not like I ever had any of that happen or anything.
A few observations:
Elbow grease will never come in tube.
Dirty fingernails don't make you a man ........... broken fingernails now that makes you a man.
There's no shame in owning no tools ............. just as there's no shame in holding your wife's purse for a minute.
How many tools can a man own ........... don't ask questions with no answers
Never borrow tools. Never ask directions.
Skin care products for men - Oil, brake fluid, lithium grease, blood
No man's legacy should be a heart shaped bird-box.
Cold dinner ......... another sign of a job well done.
You can tell how good a power tool is by the size of its warning label.
The job isn't done till you've drawn blood.
Measure once cut twice........or measure twice cut once.
Any project is a good excuse to buy more tools.......or upgrade on what you've got.
18v drill or gear drive drill
a device used to sprain your wrists right as you finish the hole
axe
a tool used to make the wood inevitably droped on your toe smaller
dremal tool
a device used to destroy all those expensive little bits sold sepratly
wireless keyboard
piece of crap that makes you look like you didnt graduate grade school cause it constantly stops working momentarly mid words < see just look at this post
staple gun
pre sets staples so you can finish knocking them in with aa hammer Maybe i just need a new staple gun
saw a t shirt one that read "Sex is just the sublimation of a man's underlying desire to buy more tools"
It is quite amazing how many of those i can completely relate to on a personal basis!!
I've seen this about ten times, and STILL get a good laugh.
Not that I can relate or anything. Now, where's the G**D*** bandaids? Nevermind, hand me the duct tape.
No, I'm NOT going to the doctor, it'll heal in a few months all by itself. ;-P
Dave
Classic and hilarious. I can't think of a better way to spend a day than drooling over new tools at a homecenter. And yet I end up with all of the issues you have described above only to go back for more punishment. I just can't stand the idea of paying someone when I think I can do it myself.
Shane
garage .
Snap rings are also called Jesus clips because of what you utter when they take flight. Most of the tools mentioned require the tongue be held a particular way. %-P
