I thought I would write some Observations and opinions on the pros and cons of running a pellet stove on a thermostat as compared to runing a stove constantly.
We have used our Quadrafire 1000 since purchasing it new back in 1994.
For several years the Quad was the main workhorse used to heat the 2400 Ft ranch style home.
The Quad as many know, runs on a T stat and comes on and off as needed. The variation in room temps will vary about 5 degrees or so from the time the stove turns off until it comes back on again.
The T stat is located centrally to try and keep the house temps more even.
We currently have two whitfield manual lite (constant run type stoves too.
What I have observed is that with the Quad, the temperature in the outer areas tends to stay cooler and the overall "comfort" is not as good with the Stat controlled stove.
Everything in the room adds to or subtracts from the temperature. The contents of a room (furniture) acts as a giant heat sink. If the whole room cools off, it takes far longer to get it back up to temperature.
For example
The room has cooled down to say 65F and stayed there for a few hours, the stove comes on and the room "AIR" is heated back up to 70F, the stove turns off and the "Gaint heat sink" starts to suck up the heat over the next few minutes or hours.
The amount of heat required to get everything back up to the "comfort zone" is far more than what was added to the room during the controlled burn of the stove, that may last only a short time.
I have found that once the rooms and the contents are up to temperature, it takes far less to maintain this than always trying to "Catch up"
Once we get the house at around 70F our small stove can maintain this easily on a fairly small amount of fuel (stove running on low continuously)
When the outside temps fall off drastically, of course it takes more fuel to heat the house but, the contant burn of the stoves keeps the drafty feeling away.
The overall comfort seems to be much better with a constant fire than with the on/off cycling of the Quad (or any stat controlled stove)
During the shoulder seasons this is not so much of an issue, as the heat loss is much less.
During some particularly cold weather, I have observed that as soon as the Quad would shut off, the feelings of cool drafts would come in almost immediately.
There is surely the need to have a Stat on a large stove as it, even on low, in many cases would be way too much heat for the given footage its heating.
Just some thoughts on keeping a large home cozy without being too hot or too cool.
Snowy
For example
Snowy
