Garn wood usage?
Benwa907 Posted By Benwa907, Nov 20, 2012 at 8:06 PM
  1. Benwa907
    Benwa907
    New Member 2.
    NULL
    Nov 16, 2012
    3
    0
    Loc:
    Fairbanks
    I'm looking for some real world numbers on how much wood garn owners go through yearly. I'm looking into getting one in the near future and am curious. Right now I am going through close to 1000 gallons of heating oil per year, how close is the 1chord equates to 150 gallons of oil estimate?
  2. Clarkbug
    Clarkbug
    Minister of Fire 2.
    NULL
    Dec 20, 2010
    1,204
    144
    Loc:
    Upstate NY
    Welcome to Hearth!
    I think you will find you wont get a great answer, because the amount of wood Garn users go through will be dependent upon the loads they serve, the species of wood, and the moisture content of that wood.
    The 150 gallons to a cord will vary depending upon the type of wood you have to burn. Good seasoned hardwood may yield better results, while something like poplar or pine may be closer to 100 gallons per cord... (Im just making those numbers up off the top of my head, there are actual listings of BTU values for each type of wood). That said, a pound of wood has a given BTU value, so its all about the wood density and moisture content.
    Heaterman could tell you all about Garns and if they are right for your application.
  3. Kemer
    Kemer
    Member 2.
    NULL
    Feb 26, 2008
    213
    3
    Loc:
    Northeast Pa
    I used about a 1000 gal and use about 6-8 cord per year
  4. mikefrommaine
    mikefrommaine
    Guest 2.
    NULL
    I don't have a garn but have found the 1 cord/150 gallons estimate to be accurate. Could probably do better with the right dry wood.
  5. wardk
    wardk
    Feeling the Heat 2.
    NULL
    Jul 19, 2012
    262
    61
    Loc:
    B.C. Canada
    It's my first season with the Garn I'm est 8+ the way it's going, Standing dead Fir and Pine for fuel , a large heat load with the house and shop, but have never been warmer the wife loves it. I dream about your equipment list for processing firewood, can you explain Garn vertical?
  6. BHetrick10
    BHetrick10
    Member 2.
    NULL
    Dec 7, 2010
    107
    0
    Loc:
    Central PA
    Garn makes units with the chimney vertical for those areas that cant have the horizontal chimney.
    Happy Thanks Giving!
