    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    My wife and I are designing our new home to be built in southern Michigan. We are considering using a LP gas log fireplace in the living/family room and also installing a woodburning/pellet stove in the basement directly below. What are your thoughts? Can they use the same chimney?
    Answer:
    They can not use the same chimney
    1. A pellet stove does not need a chimney. It uses a "direct vent" right thru the wall.
    2. many LP fireplaces also can use a direct vent...but if you are getting a regular wood fireplace with gas logs in it- then you need a full fireplace (usually metal) chimney.
    3. If you get a woodstove in the basement- it needs it's own class A chimney- either masonry or metal
    #1
    Helpful Sponsor Ads!
Thread Status:
