Q&A Gas Log for a Franklin Wood/Coal Burner?
Post in 'Questions and Answers' started by QandA, Oct 27, 2004.
Thread Status:
  1. QandA
    QandA
    Expand Collapse
    Staff Member
    Nov 27, 2012
    0
    5
    Question:
    Can a Gas Log be installed and used safely in a Frankling Cast Iron freestanding fire place ( Gas Log vented &/or Ventless)? Presently thefranklin is used for burning wood or coal- and has an eight inch stainless steel double wall chimney with a damper. I have provision for natural gas. I usually burn an approximately 16 inch long piece(s) of wood. Your answer please. If yes- what gas log would you recommend?
    Answer:
    You need to use a small set- and then only with the doors and damper full open. Peterson is one major brand that we have put this question to- and they said as long as it fits- and has a 8" flue.This will not be a heating solution- just for looks..as all the heat (or most) goes up the chimney. If you want heat- get a new gas stove.<p>
    Such an installation can only be used with the doors of the Franklin Fireplace fully open.<p>
    Most importantly, make certain the manufacturer of your set OK's the specific use.
    Helpful Sponsor Ads!
Thread Status:
