Glass cleaner
CrowBean Posted By CrowBean, Nov 25, 2013 at 8:23 PM
Thread Status:
  1. CrowBean
    CrowBean
    Member 2.
    NULL
    Jun 30, 2011
    87
    4
    Loc:
    Cumberland, RI
    I have a spot on the inside of the glass that feels rougher when I clean it. It never comes fully clean and leaves a "cloudy" spot. Does anyone have an idea how to fix this? I usually use soap and water to clean it.
  2. SmokeyTheBear
    SmokeyTheBear
    Minister of Fire 2.
    NULL
    Nov 10, 2008
    13,363
    1,662
    Loc:
    Standish, ME
    Take a damp cloth dip an end of it in the pellet ash and use that on that spot, then using a clean spot on cloth wipe that area clean. The ash is just about perfect in the abrasive department to remove condensed wood volatiles from glass.
    EastMtn and The Ds like this.
  3. CrowBean
    CrowBean
    Member 2.
    NULL
    Jun 30, 2011
    87
    4
    Loc:
    Cumberland, RI
    Thanks I'll give that a try next cleaning.
  4. guitarjamman
    guitarjamman
    New Member 2.
    NULL
    Sep 26, 2013
    52
    15
    Loc:
    Central MA
    I used a glass stovetop cleaner on my pellet stove and boy was it a mistake. It worked like a charm to initially clean it but it left a layer that I couldn't see and burnt big time on the glass after firing up again. Maybe I messed up and didn't wipe it clean enough, but I had to resort to a razorblade held on a 10° angle or so to scrape it all off. It works wonders for getting most really tough spots off - just be extremely careful to not hold at too steep an angle. A nice scratch in the glass will forever sit in your mind.
  5. Cincinnati Kid
    Cincinnati Kid
    Feeling the Heat 2.
    NULL
    Jan 6, 2009
    290
    13
    Loc:
    Cincinnati
    I used to have a Whitfield insert stove where the glass would start getting dirty minutes after lighting the stove. I purchased some good old fashioned oven stove cleaner and sprayed it directly on the glass at room temp. I would ipe the glass off with either paper toweling or news paper. That took all the crap off the glass. Iwould then followup that up with Windex and the glass would be sparkling clean.
    Since i've since replaced the Whitfield with a Harman, I use regular wood stove glass clean clear that works fairly well.
  6. Bioburner
    Bioburner
    Moderator 2.
    NULL
    Staff Member
    Aug 4, 2012
    7,147
    1,511
    Loc:
    West central Mn
    Have to carefull with what cleaners are used as some stoves use ceramic and ammonia can cause yellowing and other unfortunate issues.
  7. tjnamtiw
    tjnamtiw
    Minister of Fire 2.
    NULL
    Mar 9, 2009
    4,432
    725
    Loc:
    North Georgia
    All you need is a paper towel and water IF you haven't already attacked the special glass with some fancy 'super duty' cleaner and ruined it. An occasional buff with pellet ash and water, as SmokeytheBear says, can't hurt. All the other crap mentioned is just making matters worse. The glass WILL get dirty so live with it and clean it once a week when you do your weekly ritual.
  8. P38X2
    P38X2
    Minister of Fire 2.
    NULL
    Mar 11, 2012
    1,670
    402
    Loc:
    Jaffrey, NH
    I use glass cook top cleaner, either Weiman (Walmart, etc) or Rutland ( HD, etc- stove section) brand. Both work great. Pretty sure it's the same glass.
    I don't like to use ash because IF there is some sand in the ash, your likelihood of scratching it is far greater. Kinda like when you are waxing your vehicle and you drop the applicator or buffing cloth on the ground and then keep waxing/buffing....and then wonder where the circular scratches came from.
  9. nailed_nailer
    nailed_nailer
    Minister of Fire 2.
    NULL
    Oct 29, 2007
    861
    130
    Loc:
    Cape Cod, Ma
    I clean the glass with a plastic scotch-brite sponge. The yellow one with the green scratchy side. Avail at any grocery store.
    I scrub the glass with the water dampened green side. This knocks all the loose stuff off and makes a slurry.
    Then I wipe it clean with the sponge side.
    The follow that up with a dry paper towel to buff it.
    If there are any stubborn areas I use the green side dipped in ashes.
    Once super clean I use Rutland Stove Glass cleaner. To clean/seal it.
    It seems easier to clean next time after I use the Rutland product.
    Good Luck,
    ---Nailer---
  10. P38X2
    P38X2
    Minister of Fire 2.
    NULL
    Mar 11, 2012
    1,670
    402
    Loc:
    Jaffrey, NH
    +1 on the Rutland stuff with silicone making subsequent cleanings seem easier.
  11. EZsteve
    EZsteve
    Member 2.
    NULL
    Dec 26, 2010
    129
    9
    Loc:
    Central Va
    Just a paper towel barely damp.Then wipe dry.
    tjnamtiw likes this.
  12. boo boo
    boo boo
    Minister of Fire 2.
    NULL
    Dec 22, 2012
    505
    137
    Loc:
    So. NH
    I use newspaper and water. The political section cleans it up pretty good
  13. Justin M
    Justin M
    Feeling the Heat 2.
    NULL
    Dec 22, 2008
    283
    86
    Loc:
    Southbury, CT
    I use a damp paper towel dipped in ash if needed. Then follow up with a dry paper towel. There is no need for the harsh chemicals.
  14. St_Earl
    St_Earl
    Minister of Fire 2.
    NULL
    Sep 9, 2011
    1,337
    344
    Loc:
    millinocket, maine
    i have always cleaned the glass with a moistened folded couple of paper towels.
    what's new is i have put several thicknesses of duct tape folded over on the end of the shop vac hose (to keep from scratching anything), and i vacuum the metal edges around the glass and also vac the bulk of the ash off the glass before i wipe it clean with the paper towel.
    then i buff it with a soft cloth.
    the only time i ever needed to scrub with ash was when i had gone a very long time w/o cleaning the glass.
    got a little cooked on translucent light brown residue then.
  15. glenc0322
    glenc0322
    Minister of Fire 2.
    NULL
    Dec 30, 2011
    605
    86
    Loc:
    long Island NY
    I just clean the glass on Sunday with water and a paper towel then dry with a paper towel stays clean for a well then do it again
  16. David Holmes
    David Holmes
    New Member 2.
    NULL
    Oct 16, 2013
    35
    8
    Loc:
    North Bay, Ontario
    Use a 50/50 mixture of water vinegar, best yet.
  17. P38X2
    P38X2
    Minister of Fire 2.
    NULL
    Mar 11, 2012
    1,670
    402
    Loc:
    Jaffrey, NH
    Sometimes you gotta give the glass a full.....ah, nevermind ;)
    boo boo likes this.
  18. Harvey Schneider
    Harvey Schneider
    Minister of Fire 2.
    NULL
    Oct 9, 2012
    1,321
    322
    Loc:
    Southbury, CT
    I remember reading on this forum, last year, that cleaning products with ammonia will permanently cloud the stove's window. Windex has ammonia in it.
    I haven't verified the validity of that warning, but I would err on the cautious side and avoid window cleaners.
    My own preference for cleaning the window on my MVAE is Rutland stove glass cleaner. I use it weekly when I clean the stove.
    As for the cloudy spot you mentioned, I haven't found anything that will entirely remove it. I tried a mild abrasive on my PDVC and it improved the transparency of the window, but it didn't remove the cloudy spot entirely. To me, it's not worth the cost to replace the window.
  19. CrowBean
    CrowBean
    Member 2.
    NULL
    Jun 30, 2011
    87
    4
    Loc:
    Cumberland, RI
    Good thread. Thanks guys.
  20. SXIPro
    SXIPro
    Minister of Fire 2.
    NULL
    Sep 28, 2009
    705
    219
    Loc:
    Northern MA
    Mr Clean Magic Eraser
Thread Status:
