Good Thing for Warrantee
Ejectr Posted By Ejectr, Mar 18, 2013 at 2:43 PM
  1. Ejectr
    Ejectr
    Minister of Fire 2.
    NULL
    Nov 1, 2009
    565
    54
    Loc:
    Brimfield, MA
    Or this would be getting expensive. Lost another hopper fuel level sensor in the PF100. That's the second one in two burn seasons. They run around $100. So 2 @ $100 and an igniter @ $115 =$315 in rinky dink parts alone in not even two seasons of run time.
    Oil Furnace 3....Pellet Furnace 0....
  2. gbreda
    gbreda
    Minister of Fire 2.
    NULL
    Aug 3, 2009
    1,255
    282
    Loc:
    Lakes Region, NH
    Is this normal? I had heard about going thru burn pots but not so much on the other stuff.
    Also, Is this a similar set up to the PB units? I would think it is to a certain extent, at least in relation to the part issues you are having
  3. kinsmanstoves
    kinsmanstoves
    Minister of Fire 2.
    NULL
    Aug 29, 2007
    3,480
    501
    Loc:
    Ravenna, Ohio 44266
    That is strange. Never heard of one going out.
    Eric
  4. Ejectr
    Ejectr
    Minister of Fire 2.
    NULL
    Nov 1, 2009
    565
    54
    Loc:
    Brimfield, MA
    First sensor was DOA upon initial install. Got a replacement that lasted the whole season last year and up to last night this year. It's not that complex a part. An LED and a photo sensor.
  5. Ejectr
    Ejectr
    Minister of Fire 2.
    NULL
    Nov 1, 2009
    565
    54
    Loc:
    Brimfield, MA
    Back up time....I let the hopper pellet level go way down to the bottom so I could do some more investigating. Got the sensor cleared of all pellets and brushed away the saw dust that had collected around it. Then I noticed a small flap of RTV I had used to seal the hole it goes through flapping loose. It was excess RTV that had come out from under the sensor when I sealed it and dried. Over time the excess had lost its adherence to the metal and was like a flap. I trimmed around the sensor with a razor blade...ran the test again and this time it worked. I covered the sensor with pellets....waited 3 minutes and the low fuel level light went out. The wall controller also quit flashing.
    So it was either the saw dust build up....the flap of dried RTV or a combination of both. So I'm back in business.
  6. dhall28
    dhall28
    Burning Hunk 2.
    NULL
    Mar 2, 2013
    182
    35
    Loc:
    Central Ohio
    good to hear its ok, i was scratching my head at this one, although stranger things have happened personally I have never come across a pf100 with a bad hopper sensor.
    kinsmanstoves likes this.
  7. Ejectr
    Ejectr
    Minister of Fire 2.
    NULL
    Nov 1, 2009
    565
    54
    Loc:
    Brimfield, MA
    The first one I replaced was definitely bad. Tested bad and problem cured after replacement.
  8. dhall28
    dhall28
    Burning Hunk 2.
    NULL
    Mar 2, 2013
    182
    35
    Loc:
    Central Ohio
    i never doubted the first one, that sort of thing happens, probably made on monday or friday, but i should say, i've never seen one that did work go bad after a while. most of the warranties i have with harman's are from newly installed units, most but not all.
