Harman Advance Auger Motor Replacement
Fire
67
NYC
Can anyone advise instructions or a link to replacing an auger motor on the Harman Advance. I purchased an OEM motor online which I should have in two days and want to be prepared for an easy replacement. Thanks in "Advance".
there's actually not a lot to it.. the trick usually is moving the cam arm out of the way. you may want to remove the access door to the fines box, so you have some more play on the slide plate. when you tension up the chain drive, don't make it super tight and make sure that the 2 sprockets are on the same plane with each other. if they aren't lined up it can lead to the chain jumping during and high tension event. theres only 4 fasteners on the motor to the bracket, 1 set screw each on the sprockets, and you're good to go.
