Went to start my P61A-2 for the first time this season and igniter light didn't come on. (It had stopped coming on automatically at the end of last year and I figured I just had to clean the fly ash from around the ignitor) Cleaned it out and the igniter light wasn't coming on. When I put it in test mode, everything comes on except for the igniter light. Without checking further (the fuse is fine), I bought an igniter from Grainger (mentioned elsewhere on this site). While trying to figure out which wires went to the igniter, I unbolted and removed the esp probe. Figured out the igniter, installed it and started the stove and the igniter worked fine. Started smelling smoke and realized I hadn't put the esp probe back. I shut the stove down, cleaned the probe and put it back in. Thoroughly cleaned the stove and put all the shields back together. Went to try the stove and the igniter light isn't coming on again. Tested the ohms on both the new and old igniter and they are fine. All the wire connections are tight. Started the stove manually and everything seems to work fine as far as the temperature controls and both fans, except with it in the off position, the stove continues to cycle pellets at a low rate. It went on for a few hours continuing to feed pellets and I finally unplugged it to shut it off. Any ideas as far as the igniter not working? Sorry for the long post, but wanted to be specific.
