Harman Users: Switching between Stove & Room Temp.
THE ROOSTER
Does anyone switch between the two once the stove is burning??? I normally burn in stove temp but was wondering about switching it to room temp and wondered if I needed to shut the stove down or just switch it while it was burning???
My stove does not burn near as hot on stove temp as it does on room temp, even when the dials are maxed out, so on a really cold night I am thinking about switching it to room temp and wondered the best way to do this...
I have been running my P61A in stove temp for the last few weeks as it has been right around 0-10* F. The last 2 days or so it has been up around 25-35* and right now is 37* outside. I came into the house and the room the stove is in was 81*. So, I switched it to room temp. I don't know if its good or bad, haven't seen an issue. The only thing it does is cycle down since its SO warm in the room.
Rooster,
You don't say which stove you have but it's probably similiar to my xxv. To dial between stove temp. and room temp. you have to go through the off setting. Thus you aren't really going from one to the other you're actually turning it off then turning the other one on. I haven't noticed any problem with quickly going from one to the other. I agree with you that room temp seems hotter. I get 260 degrees at the distribution air site when it's going good on room temp. it's hot. I haven't tried to crank the stove temp yet though. I'll bet that someone out there can say whether you have to "sit on" the off setting for some period of time to get it to register but I don't think it matters much anyway. The stoves seem bulletproof. Except for that damn buzzing noise.
happy burning
clifford
I stop at the off position for 5 seconds when changing modes.
you can go from one to the other with no problem . just turn knob at any speed.
Most of my customers claim they like the ease of the room temp mode but the die hard burners like the stove temp mode because it lets them fine tune the feed rate better. I run the PC-45 that is in the store on room temp mode 99% of the time.
Eric
Hmmmm.....on my PC45, it's WAY hotter on Stove temp. On Room temp, my wife starts to get the chills. On Stove, it works much better for me.
What model do you have?
WIth mine, the P61A, I don't know if the air coming out of the blower is hotter or not. I think it feels hotters in stove temp because it never cycles down, its going at a constant temp. Here is an example, yesterday with temp in the upper 30's i set the stove on Stove temp at about 2.5 on the dial. The room the stove was in quickly went from 65 to 68 to 71 and up to 77. It felt HOT in that room but it was 77 degrees. On room temp at the same setting it would have never gotten that warm in the room, it would have cycled down before that but at the same time it wouldn't have gotten much warm air to the rest of the house either.
Yes, it feels 'hotter' and it doesn't cycle down. You described it better. ;-)
always use stove temp, but its only been installed a week... my understanding is that it burns the same amount of pellets on any setting, due to the draft being the same, and the only control over the amount burned is the feed rate.
on room temp it is trying to adjust to the immediate surroundings... maybe good if you have alot of airflow to other parts of the house, or dislike the stove room to be hot.
keeping it on stove temp, and keeping the fan on high, seems to get the most efficient heat out of the lowest pellet feed, granted its louder.
so I cycle (toggle) between high and low fan, depending on my need for heat, and burn one bag in about 14-15 hours, then let the furnace go on at night/early morning when the temps drop below 55 indoors...
fan is usually on low, and set between high and low on the dial...furnace stays off unless temps drop below the teens..feed rate always at 3, barefoot hardwood.
Anka
Anka
Yep, it works extremely well with Barefoot. It didn't work at all on those settings using Tree Cycle.
The manual says I can switch modes at ANY time. I don't stop at off, I just put the stove in the mode I want. I always leave the stove in room temp mode until I was experimenting with the backup battery system and true sine wave inverter. Putting the stove in manual, and stove temp mode uses significantly less electricity.
