    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    I just completed building a hearth for my wood stove. My wall is
    protected with durock covered with Z-Brick.
    The durock is hanging on several metal studs which are connected to
    sheetrock which is connected to plaster which is connected to a brick
    wall. No wood in wall.
    The metal studs keep the durock spaced 1 inch from the sheetrock with
    ventilation on the top and bottom of the hearth.
    Is this construction ok??? Thanks for your help.
    Answer:
    More than good enough. If there is not any wood in the wall, then you are doubly safe. All clearances from stoves are given to combustible materials. Since there are none there, you are more than fine.
    #1
    Helpful Sponsor Ads!
Thread Status:
