    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Jimmy Member
    Hi everyone, I recently purchased a Clydesdale. The seal (feels like wool) that goes around the opening for the door to create a seal has completely fallen off after one use. I am baffled as to what may have caused it. Has anyone ever had similiar issue? Any guess on what may have caused it?
    I followed manual and slowly broke in the stove, small fires etc... for several hours... I ran it for about 10 hours in total on day one and after 4 hours of "breaking in", I got it to 400 degrees. At some point it did get as high as 700 when I was looking but that was only for a short time and then I would damp it down.
    Did I over heat it... please help, this is very frustrating.
    Thanks everyone for your help
    #1
    Helpful Sponsor Ads!
  2. pen Super Moderator
    N.E. Penna
    Sounds like the factory might have not glued that gasket on appropriately. I'd contact your dealer and ask about him coming out to fix or him providing you with a tube of gasket cement to reattach yourself so long as it is not damaged.
    700 is higher than you should see on a break in, but that certainly didn't cause your gasket issue. If anything, the gasket issue might have caused you to hit a high temp so easily.
    Hitting 700, even on a new stove, should not hurt a thing. If it did, then there is a problem with the stove.
    pen
  3. ernie Member
    Missouri
    Common problem, my guess is the curing paint gets sticky on the first couple of fires and when you open the door, it pulls loose. I have seen it quite a few times across many brands. Just glue it back, I should not happen again.
    webby3650 likes this.
  4. webby3650 Minister of Fire
    southern Indiana
    That's exactly right! I had to go back on a new Clydesdale recently. As the gasket cement cures, it oozes a little, causing the gasket to stick to the door.
    Some stove manuals say to leave the door ajar for the first fire to prevent this from happening. Just glue it back on.
  5. begreen Super Moderator
    South Puget Sound, WA
    You've done nothing wrong. It can happen and must be fixed.
    The door gasket is critical to the stove operation. It will need to be glued back in place. Have your dealer come out and fix it. Let the glue dry for a day before using.
  6. Jimmy Member
    Thanks !!
    Good to know that I didnt damage anything. And actually i didnt get past 600, i was wrong, wife corrected me.
  7. ernie Member
    Missouri
    You don't need a dealer to come out to fix something this simple, all you do is squirt the glue in the crack and press it in place! So simple a kid plus do it. Just have them send you the glue.
  8. BrotherBart He Who Moderates
    Northern Virginia
    For what you paid for that puppy, let the dealer come and fix it.
    pen likes this.
  9. webby3650 Minister of Fire
    southern Indiana
    It is simple, but give them the opportunity to make it right. Unless you installed it yourself, then I think you should go ahead and take care of it.
