Local ad, worth it? Looking for good size basement stove.
http://boston.craigslist.org/sob/hsh/5206035168.html
The fireplace has a 16" deep, 13" high, 71" wide hearth. I was thinking insert.I would just go new in that case. For value consider either a Drolet or an Englander 3 cu ft stove.
That's a pretty nice looking stove., but 26 1/2 deep, will that fit?The Drolet Escape 1800i is 2.4 cu ft for around $1100.
http://www.northerntool.com/shop/tools/product_200577755_200577755
Is there any reason not to use all flexible, insulated ss liner?When a straight shot of pipe can't negotiate anomalies in the chimney. Some sweeps use it all the time. Very often it helps to end in a short section of flex to negotiate through the damper area.
Not really.
This Flex Kit is meant to be used in an existing chimney, for this application no insulation is needed, and insulation is not available through Northern Tool.
I'd shop around a bit. There are other liners out there. chimneylinerdepot and Rockford Chimney Supply are two big companies selling liners. A poster just ordered his liner via discountchimneysupply and has been pleased with their prices and service. I've had good luck with woodstovepro.com.
