Hello, I'm new to this forum although it feels like I've spent many waking hours on it lately. Thanks for all the great posts!
We just broke ground on a new house in Idaho. The climate here is cold, cold in the winter. We often have the coldest temps in the country on any given day, it's commonly below zero and often -20. We have a TON of beetle kill lodgepole pine, and although it isn't the best firewood it would be a sin not to burn it in a stove before it burns in the forest. It's dry as a bone the moment you cut it. The house we're building is 700 sf ft each in the basement and on the main floor. The floor plan is open with an 11' vaulted ceiling on the main floor. Wood heat will be our primary heat source. We'll have 2x6 walls and decent insulation and good windows and doors. The stove will be on the main floor, and we'll likely install propane backup heaters in a few key locations in the the house.
Obviously for a well insulated house of this size, we don't need a huge stove. We also don't like our inside temps over 70, we're cold blooded. Our search for a stove has been fairly humorous. We started out looking at very small models. We really like the Hearthstone stoves, but can't really afford one. We saw a new Tribute (1.2 cu ft firebox) on sale locally for $1000 and tried to convince ourselves it would be enough. Looked at other small stoves before deciding we wanted something with at least a 2 cu ft capacity. Started to decide on a Napoleon 1400 until lo and behold a used Hearthstone Mansfield (3.2 cu ft) showed up on Craigslist for $1500.
So we went from looking at too small to potentially too big. Most regular posters here subscribe to the bigger is better philosophy, but is there a limit? Would this be exceeding it? Would this stove operate efficiently if we're constantly running it half capacity or less?
The stove is a long drive from here and I'm doing the best I can to ascertain it's in good shape, so far so good. Supposed to get more pics tonight, but no cracks in the stones and nothing in the firebox appears cracked. Unsure of age but guessing 5 years or more. Any suggestions for things to look at on the stove?
On another note, I'm thinking of installing an air duct that blows air from the vaulted ceiling peak down into the basement. Are these worth it? Any design thoughts - keeping in mind I need to keep it cheap and simple? Also worried about fan noise, but wouldn't be a huge issue if the blower were in the basement.
Thanks for the help!
