Heat n Glo Gas Stove Coming on By ITSELF!
LAndrim
94
Outside of Philly
Hi,
Anyone ever heard of a gas stove lighting itself??? I have a HeatNGlo Tiara I stove. It has been coming on by itself...can't understand how the toggle switch can be pushed without a finger engaging it. Any suggestions? Thanks much
Hi Bob, no there is no remote. Not sure if this helps, but I sometimes have to push the toggle switch 3 or 4 times before it starts. But it starting on its own is a little scary. Thanks for any help
Pull the switch & check the wiring. There may be a short.
If the stoves does NOT come on with out the switch in it.
that is probably your problem.
Does it ever turn OFF when burning?
No, it does not turn off. Let me check the wiring on the switch later today...
thanks for your quick reply and stay warm, especially with this Nor'easter coming our way!
Reactions: DAKSY
Hey Dansky...finally looked at the toggle and wires...I definitely need a new one but in looking around, all I could find is an off/on toggle switch with 2 wires, plus the tag on it says "for remote or wall use only".
Not sure if this will work, mine has 4 wires coming out. Any suggestions?
P.S. I am NOT a stove person...minimally handy, but not a expert with these things. thanks!
That switch should work.
You have 4 wires coming off 2 spade connectors.
Just plug the switch in in the same way as the OEM.
thanks much for your expert advice and help. stay safe, and of course , warm!
Reactions: DAKSY
