flyingcow
And if needed, you can easily haul a 40/50hp. or smaller tractor with a 1/2 ton pickup. My unit needs 3/4 or better.
oh yeah...you should have seen me go down the hill....could have roasted a pig and downed a six ....And I'll bet you moved that load like a good BBQ. Low and slow.
I guess I'll be a bit contrarian here.
I'm doing pallets. I actually took a pallet of firewood that was pretty much green down to the scales. I can't remember exactly.. but I was around 1500lbs.
I do have forks that are mounted on a skid steer plate. So it's closer in with the load. My issue ended up being height, as I stack 3 high. So I ended up with forklift. I could have easily stacked 2 high with the tractor.
My tractor is a 35 horse kubota L with a cab and loaded tires.
If you're going to use standard pallets. That's a 40x48. I cut 24" wood. so two rows stacked. I use cross boards to hold the top of the pallets together. That ends up being 48x40x36 or so (pallets overlap at the base). I usually round over the top with the odd pieces.
3.3 pallets of firewood per cord.
The bigger issues are this. Pallet forks need to be 4' or better length, otherwise the forks don't lift flat, and I've dumped a few stacks by boards underneath breaking. A piece of plywood across the bottom of pallet sometimes doesn't hurt either. With short forks you need to make sure your ground touching boards stay rugged. It's tippy if you aren't reaching all the way thru. I'm spoiled now with a real forklift and 6' forks. Much more secure.
The other hard part is this. You gotta be slow and smooth with the tractor. The higher you lift, the more tilting you'll have to do. Go very slow. Think of it this way, you're moving a whole lot of wood at once. You don't need to be fast.
my tractor has a lift capacity of 2300 pounds.I can lift my palette of green wood that is about 59 to 62 cu/ft pallet very very easily. my wood is stacked two rows of 20 inch wood. Time is 48 inches long times 48 inches high. And I round the pallets up just as much as I can. 40 inches times 48 inches x 48 in inches = 92160 inches. There are 1728 inches in a cubic foot. I think I did the math right?
skfire, Sorry, but like a fool, I thought I was on the second page when I responded to David about the weight of red oak, I didn't realize there was a whole page ahead of my response and that you had already given the weights of wood. If you put my answer at the end of the first page, it'd make more sense, it'd still be a screw up though.
Contrarian......is that like being in pain in the ass but being correct about it?
David, I'm going to blame it on senility, but I've heard there some perks to senility, first one is "you can hide your own Easter eggs".
