Help with Insert for corner fireplace
shiratea
3
Muskoka
Hi everyone,
I'm new to this. I have a corner wood fireplace and am wondering if it is possible to get a wood stove insert that fits it (ie if there is one that already fits or that can be ?cut to fit). I've attached a photo. Dimensions are in the attached document.
Thanks so much!
Fireplace.jpg Help with Insert for corner fireplace
You can probably find one that fits in the there,
but you will have to fab up some metal panels,
or have some stonework done, to fill in the gaps
on either side
on either side
Thanks! When you say fab up some metal panels (I'm a total novice here...), do you mean to cover the side (around the corner) or to frame the insert? I contacted a company about intallation and they said they weren't sure they could figure it out!
You will have to cover the opening on the right (short) side,
& partially wrap around the front to cover that small "jog."
You will also have to cover the angled opening on the left side.
They will have to be anchored to the existing stone at the top,
bottom & to the stone on one side for rigidity..
They will need to be flush with the facing above the fireplace
opening & will be partially hidden by the insert's surround...
If it were mine I’d consider something like the pacific energy neo 2.5 and maybe skip the surround. Clean modern ish lines would fit nice with all the angles of the stone work. Or use a single piece that angles from the insert corner to the vertical edge on the short face. That would’ve leave the top corner floating and might look neat??? At any rate I would keep the surround inside the opening and not cover up any stone as it will just draw more attention to the corner of the surround if you have it keep the shape of the opening. Just my thoughts
evan
