Hey Mike or others/PDV
EWILT
46
Wyoming
I have a 25 PDV purchased last year (Oct). Mike and the fellows at Englander got me real close to a perfect burn last year. We played with the settings and changed to a 3 inch OAK. This stove is close but I think more tuning is needed. I get a filled up burn pot after 6 hours. I'm wondering if I should adjust the plate inside the hopper. Could there be too much feed coming down the auger? The stove burns better when the Wyoming wind blows direct into the vent from the outside...we have adjusted all the settings last year and it seems like it's still not burning to the fullest capacity. It's that time of year boyz fire up them stoves. Thanks for all the advanced help as my wife has once again started to call me a "pellet head" again.
Eric
Have you tried closing the plate in the hopper all the way? This will decrease the amount of pellets dropped into the auger(s).
As rap69ri said, try closing the restrictor plate and make sure the stove is clean. Correct fuel feed plus proper air flow means good combustion. Don't forget to check the small grate on the outside of your OAK. I use a small wire brush and a toothbrush to clean mine.
Sounds good...thanks for the help. I'll let you all know how the progress is going. Thanks
Eric
