high octane
shawn6596 Posted By shawn6596, Oct 10, 2013 at 10:41 PM
Thread Status:
  1. shawn6596
    shawn6596
    New Member 2.
    NULL
    Sep 7, 2013
    86
    25
    I still have 8 gallons of 110 octane left over from race season(the purple stuff). I was thinking of mixing some up for my 850 promac. Anyone have any thoughts on this?
  2. pen
    pen
    There are some who call me...mod. 2.
    NULL
    Staff Member
    Aug 2, 2007
    7,779
    1,532
    Loc:
    N.E. Penna
    In my experience, if an engine isn't high enough compression to take advantage of the octane, you aren't gaining anything other than using it up.
    pen
    jharkin and BrotherBart like this.
  3. Jags
    Jags
    Moderate Moderator 2.
    NULL
    Staff Member
    Aug 2, 2006
    17,509
    6,077
    Loc:
    Northern IL
    I wouldn't use it in the saw. It was never designed to run that stuff. Mix it a couple gallons at a time with an 87 octane fuel up for your vehicles. You will end up with a 90-93 octane mix (depending on size of tank).
    It ain't worth knocking a hole in the top of your piston.
  4. JOHN BOY
    JOHN BOY
    Minister of Fire 2.
    NULL
    Sep 20, 2012
    532
    291
    Loc:
    Western Mountains ,NC
    I even doubt you'd really gain anything at all ..
  5. rowerwet
    rowerwet
    Minister of Fire 2.
    NULL
    Sep 2, 2008
    1,211
    107
    Loc:
    Merrimack Valley, MA
    I run 100LL in all my small engines. I don't think it makes them any more powerfull.
    It does completely avoid the ethanol garbage, cost me nothing, and smell awsome!
    cwill likes this.
  6. pen
    pen
    NULL
    Staff Member
    Aug 2, 2007
    7,779
    1,532
    Loc:
    N.E. Penna
    I do miss the smell of good gas. When at a car show, and notice it, I've had good luck asking the driver what sort of plane he flies, and have been told several times if I wanted any aviation gas for the generator or similar, to just stop by! In the other cases, I've heard, "naw, my buddy flies"
    pen
    rowerwet likes this.
  7. dznam
    dznam
    Burning Hunk 2.
    NULL
    Jul 31, 2008
    114
    37
    Loc:
    Coastal ME
    I did the same thing last season with my leftover 110. Used it in my 372xp, 5100s, Husky brush saws and without exception they all ran like crap on race gas. Started very hard, wouldn't idle and poor acceleration. Mixed it down with 87 (around 4:1 87 to 110) and everything ran fine and I still got some of that "race gas exhaust" smell. Since octane essentially controls the burn rate of the gas, my theory was that the race gas simply wasn't "explosive enough" for the 2 stroke motors. Just my experience.
    pen likes this.
  8. rowerwet
    rowerwet
    Minister of Fire 2.
    NULL
    Sep 2, 2008
    1,211
    107
    Loc:
    the lead in avgas slows down the flame front, without lead high octane isn't what the motor is designed for.
  9. Mykayel
    Mykayel
    New Member 2.
    NULL
    Jan 21, 2013
    14
    3
    From a pure 'technical' standpoint, the higher the octane, the less energy the fuel contains per gallon. Theoretically, if you run higher octane gas in your car you will get worse gas mileage than if you would have run 87 octane. And the higher octane fuel is less prone to detonation (i.e. it doesn't burn as well) which is why it is required for higher compression ratios (think about diesel engines, they have 30:1 or so compression ratios and make a lot of power/torque but lighting diesel fuel with a match isn't like with gasoline). So it really isn't a surprise that running 110 octane gas in an engine designed for 89 octane would be hard to start and run like crap. We just associate higher octane gas as the "premium" gas and therefore think it should have more power and somehow make our normal engines run better which is not the case.
    BrotherBart likes this.
  10. shawn6596
    shawn6596
    New Member 2.
    NULL
    Sep 7, 2013
    86
    25
    I just wondered what it would do. Also I love the smell.
  11. Bigg_Redd
    Bigg_Redd
    Minister of Fire 2.
    NULL
    Oct 19, 2008
    4,153
    995
    Loc:
    Shelton, WA
    Same here. While higher octane in and of itself may do little for the average low compression 2 stroke engine, it has other advantages that make it worthwhile IMO. In addition to the aforementioned, the other advantages include - quicker revving, easier starting, zero carb-gumming, and indefinite shelf life.
  12. Bigg_Redd
    Bigg_Redd
    Minister of Fire 2.
    NULL
    Oct 19, 2008
    4,153
    995
    Loc:
    Shelton, WA
    What manual are you reading?
  13. cwill
    cwill
    Member 2.
    NULL
    Oct 13, 2010
    182
    14
    Loc:
    W. MI
    Same here. Have had zero issues with it and love the fact that i can mix it up and forget about it till I need it. When I need more I just run down to the local small airport and get more, It's pay at the pump and usually nobody is there.
  14. CenterTree
    CenterTree
    Minister of Fire 2.
    NULL
    Sep 15, 2008
    929
    395
    Loc:
    SouthWest-Central PA
    How do you get free fuel???
  15. rowerwet
    rowerwet
    Minister of Fire 2.
    NULL
    Sep 2, 2008
    1,211
    107
    Loc:
    work for a company that sells it, per faa regs the trucks and tanks must be sumped daily, the guys who sump it leave the buckets for me. I share it with anybody I know who wants it.
  16. shawn6596
    shawn6596
    New Member 2.
    NULL
    Sep 7, 2013
    86
    25
    If I were you I would be figuring out a way to run it in my truck
Thread Status:
