home-made vacuum breaker
Black Jaque Janaviac Posted By Black Jaque Janaviac, May 30, 2013 at 11:40 PM
Thread Status:
  1. Black Jaque Janaviac
    Feeling the Heat 2.
    NULL
    Dec 17, 2009
    450
    7
    Loc:
    Ouisconsin
    I have an extra brass check valve laying around and I just put in a sand point well. I thought maybe I could fashion a vacuum breaker by drilling and tapping both sides to accept an air valve. The hardware store has those little schrader style valves that you see on your car tires but with 1/4" npt male thread.
    With one of these one either side of the check valve I think this would allow air in should the water try back flowing, thus breaking the vacuum. This would be on the discharge side of the shallow well jet pump. Under normal circumstances the pipe between the check valve and the pump should be at system pressure, and the pipe after the check valve would lose pressure whenever the systemshut down. This is a lawn sprinkler system.
    Am I missing something? Any reason this would not work?
  2. heat seeker
    heat seeker
    Minister of Fire 2.
    NULL
    Feb 25, 2011
    2,745
    416
    Loc:
    Northern CT
    The theory seems good, but the spring on the schrader valve might not release before backflow occured. It's a fairly strong spring, with little surface area of the valve to operate it.
  3. Dune
    Dune
    Minister of Fire 2.
    NULL
    Jan 14, 2008
    3,128
    273
    Loc:
    Commonwealth Of Massachussetts
    Why not buy a backflow preventer? Pretty sure the code requires one where ever you live.
Thread Status:
