    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. ootski New Member
    Fredonia NY
    I have a Whitfield Advantage Plus, bought used but refurbed this year. Have about 1 ton thru it so far and do the weekly vacuunming which coinsists of removing burn pan, insuated brick behing and the metal deflector at the top. How far and how does one get to the blowers etc. Any info will be greatly appreciated
    #1
    Helpful Sponsor Ads!
  2. MSmith66 Feeling the Heat
    Central NY
    Some manuals show you how to remove and clean other parts of your. check there first.
    If not, I would start with the conbustion blower ( exhaust fan ) with that off you can clean the pipe with a 3 or 4" pellet brush.
    The convection blower( room fan) can be cleaned without taking it off the stove. When you need to oil the room fan, about every 6 months, you will need to remove from the stove.
  3. MSmith66 Feeling the Heat
    Central NY
    PLEASE MAKE SURE YOU UNPLUG THE STOVE FIRST!!!!!!!!!!!!!!!!!!
  4. hearthtools Super Moderator
    With the plus the dont have to remove the firebrick
    You want to Claen the ash traps by pulling the two round plugs at the bottom of the fire box and get a small hose on a vacuum and suck out the ash. MAKE SURE YOU PUT THEM BACK
    It is a good idea to take the baffle below the heat exhange and clean and scrape out the heat exchange out as often as possible.
    Once a year or more if you burn over 3 tons it is a good idea to pull the Combustion motor out of the houseing
    Remove the 11/32 headed nuts from the flang and pull the blower out
    Clean the Fan blade and clean out all the ash build up in the chambers behind the blower.
    once a year pull the room air blower (convection) and blow out the dust bunnies.
    Clean out all the dust bunnies from the area of the blowers and auger motor and clean any dust build up on the back side of the control board and limit switches.
  5. ootski New Member
    Fredonia NY
    TKS will try that
Thread Status:
