Setup:
1987 QF3000 heating a 1,500 sq ft house 24/7 at 6,000 ft elevation, not bad insulation:
Operation:
Load the stove in the morning, burn it hot, reload, char, and cruise till evening, reload, burn hot, shut down to low cruise on charred logs overnight, restart cycle next day with good coal bed. We keep the place 74 °F during most of the day, cools down to the mid sixties over night. The stove appears to be relatively efficient with nice secondaries.
Wood/volume:
The amount burned varies as, others have noted, with exterior temperatures and even amount of sun or clouds (reasonable passive solar house.) It also varies with wood-type that I happen to grab. However, I find on the warmer days (20's-30's) I grab more pine and cedar; on the cooler days (10's-20's) I will grab more oak when I have it. We scrounge our lot, so whatever the pine-borers give us or falls off the oaks end's up in the wood pile.
Typically, I bring in a small wash tub full of wood in the afternoon. I would estimate it to be about 2-3 cu feet. This is what the evening reload is loaded from. I then bring in another load that sits overnight and is used in the next morning reload. The wood is not usually in nice straight splits, since the oak limbs get a little curly. I would guess that the consumption is about 5 cu ft. per day, on average, with this mix. If I had only oak, it would drop to about 3 cu ft per day.
Gas/Electric heat bills: None. Well, ok, hot water, refrig and lights maybe runs $30-50/month with electric.
Happiness factor:
Off the charts!
