Q&A How to install ventless fireplace
QandA Posted By QandA, May 23, 2002 at 2:20 PM
Thread Status:
  1. QandA
    QandA
    Staff Member
    Nov 27, 2012
    0
    6
    Question:
    I purchased a ventless gas log fireplace and would like to install it in my home. Do I need to put anything between the fireplace or firebox and the walls? I plan on installing it in an existing corner of my living room. The walls are sheetrock with a vinyl paper covering.
    Answer:
    Typically your instructions will provide you with clearances or specifications. My experience with similar type of products is that those clearances are already "built-in" to the firebox & surrounding cabinet so that you place the fireplace assembly flush or directly against a wall without worry. The whole assembly is usually tested for such an application.
    But, re-review the instructions thoroughly just to make sure, and/or contact the manufacturer. I'm sure you'll be just fine.
Thread Status:
