Hi All,
I have a HR Saranac insert that has been great over the last two seasons. Fired it up last week and it worked fine for two days and then the auger stopped working. I tested it by applying 120V directly to the auger motor and it spun fine so I figured it was something in the control board. I tested the pin on the board with a voltmeter as the board called for auger function and received no voltage change coming out of the control board so I figured that the switch on the board was bad. I ordered a new board from Amandas Fireplace, HRSP 137S. I set the jumper to the right hand two pins which I think should be the setting for 50k BTU's.
The problem is that when I fire up with the new board I get exactly the same issue, auger does not rotate and I am reading no voltage out of the pin (measuring directly on the control board) going toward the auger motor. I am hoping that one of the gurus on this site can help me as I am stumped at this point.
Thanks in advance for any advice.
