Ideal Steel Hearth Pad Question
sheeshshe
76
Maine
I need to build the hearth this week, I will be doing a corner hearth pad and I will be using a heat shield. With using the heat shield, it says I can reduce the corner clearance to 6". The manual says that a corner installation needs a minimum of 54"x54" hearth pad, however the diagram shows a 60" pad... I don't understand the "calculating a corner hearth pad" equation that they give. Does anyone have the exact measurements for a corner hearth pad for the ideal steel with the heat shield?
Great question! I have the same confusion, as I will be installing an Ideal Steel next year. The info seems inconsistent.
Sent from my SM-G900V using Tapatalk
Wondering it this is an inadvertent copy and paste mistake from another Woodstock stove manual? It describes not centering the stove, but that would seem to be applicable to a side-loader, not the front loading IS. When in doubt, call up Woodstock.
Minimum hearth size in a corner installation must be 54”x54”
(with the front corner cut off). NOTE: On a hearth of minimum
size, the stove will not be centered left to right, but will
meet the minimum required clearances.
