Identify markings on Stihl 032 cylinder
NH_Wood
2,602
southern NH
Hey guys - just broke down an old 032 today - was pulling good compression (nearly 160psi) and piston was clean from exhaust port. Removed cylinder and piston for full inspection and all good. But, looking at the cylinder cast markings, all I see is the following numbers 928/6B - is the an aftermarket cylinder or stock? Thanks! Cheers!
Anyone have any idea? Cheers!
no id have to go find one call the stihl network for your area like mid atlantic stihl in va nc area im sure theres a northern area office to ..dont know when i could go over to mid atl stihl and get emmy lou to pull one What diff does it make is it Nikasil lined/sprayed ? do it look good ? had good comp obviously so im at a loss quite a few companies make juggs for saws many saws not something really easily fekd up either..I dont know the number by memory
Thanks Tom - I sell saw parts and haven't had one of these apart for sale yet - didn't want to advertise as a good OEM cylinder if it was an aftermarket unit. Cheers!
used saw parts i guess sir? when I was in salvage buis we just advertised parts as take offs so wether Andreas or jahns custom out west made it the perspective customer knew that running it had a 160 psi compression and was a running take off rated used part from whatever specific model.. thought I was pretty much covered ..
Yes - used saw parts Tom - if I can't find other info the the casting number, I'll likely sell as you indicated - thanks for your thoughts - Cheers!
