Insert and liner question
CheaperthanYou Posted By CheaperthanYou, Nov 18, 2013 at 7:32 PM
Thread Status:
  1. CheaperthanYou
    CheaperthanYou
    New Member 2.
    NULL
    Feb 11, 2013
    31
    7
    Loc:
    Levittown
    So it was warm here today an I decided to pull out my insert and cut my damper frame so I could Get my insert about 10 inches back into the fireplace.
    Wen I pulled the insert out my 90deg stainless swivel connection came apart. I cannot re assemble it, as its totally bent
    Can I use a black stove swivel 90 from lowes until I can get my hands on the stainless one? 2-4 days shipped to my door. No one local stocks them
  2. brenndatomu
    brenndatomu
    Minister of Fire 2.
    NULL
    Aug 21, 2013
    2,385
    634
    Loc:
    NE Ohio
    Why not? The free standing stove guys use 'em all the time
  3. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,826
    9,890
    Loc:
    Northern Virginia
    Yeah. I used one for a whole season in the fireplace until I could get a fixed stainless elbow. Didn't want to but it worked. They usually aren't that close to the flue collar in a free standing installation and don't take the fierce heat on reload. That one was tired by the end of the season.
    Figure the angle you need and get a 15 or 30 degree fixed elbow with band clamp for the liner for the next one. It will last a heck of a lot longer than an adjustable one.
  4. CheaperthanYou
    CheaperthanYou
    New Member 2.
    NULL
    Feb 11, 2013
    31
    7
    Loc:
    Levittown
    Seems like it won't really fit into a tankless liner or visa versa is there another adapter
  5. CheaperthanYou
    CheaperthanYou
    New Member 2.
    NULL
    Feb 11, 2013
    31
    7
    Loc:
    Levittown
    Quick bump, the black pipe is the same dimension as the stainless liner. What can I use. Wife is getting cold. Thanks
  6. brenndatomu
    brenndatomu
    Minister of Fire 2.
    NULL
    Aug 21, 2013
    2,385
    634
    Loc:
    NE Ohio
    It wouldn't be the best set up (VERY TEMPORARY!), but, I'd clamp the new elbow and the liner together with a pipe band. Any local hardware that carries stove pipe should have them, they are made to clamp two pieces of pipe together butt to butt, which is basically what you are doing. Just make sure you are burning DRY wood and a hot fire, you don't want to have any creosote running out of this temporary repair!
  7. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,826
    9,890
    Loc:
    Northern Virginia
    Black stove pipe male/male adapters are all over the place. That is what I used.
  8. CheaperthanYou
    CheaperthanYou
    New Member 2.
    NULL
    Feb 11, 2013
    31
    7
    Loc:
    Levittown
    thanks I finally found someone local, that had a stainless pipe and stove adapter in stock. he even spot welded it up me, and supplied some zip screws to install it to the liner
    brenndatomu likes this.
Thread Status:
