My insert holds the trim piece border with these spring clip things. They are such a pita to get in after a cleaning that i don't even use them any more. My trim looks like crap, and it rattles sometimes.
Manual states what really happens
i've rarely been more frustrated or had my patience tried harder. lol
So, is there a better way? I'd like to never touch another one of these F'ing things again, have a decent looking trim piece, and stop the rattles of the trim to surround because the aren't fastened correctly.
it needs to be removable for cleaning.
thoughts?
Install two spring clips approximately five inches from each
end of each of the three trim pieces. The spring clips should be
installed in the channel of the trim with the curved portion of
the clip to the front toward the rounded surface of the trim. they don't stay there... they simply slide/fall out. unless you have 6 hands plus 2 to move the trim piece, this is not possible.
Place the longest trim piece with the rounded surface out there is no rounded surface
along
the edge of the top surround panel with the spring clips slightly
behind the surround panel. see above about how the clips already fell out. Pull the trim forward, compressing
the spring clips, and slide the trim down onto the surround. if got this far, the second you touch these tension'ed springs, the pop out and go flying like we used to do with paper clips in highschool
Insert the elbowed retainer not sure this exists in the mitred end of the side trim
pieces and fasten with flat screwdriver. Insert the other end
of the retainer in the end of the already installed top surround
trim and slide side trim onto the edge of the side surround
compressing the spring clips in the process. Repeat the same
steps for the other side trim. the trim is one big piece, 2 sides and a top. how can there be 3 parts? Fasten the elbowed retainer again, no idea what or where this is
securely in the top surround making a nice mitred corner.
maybe that's my problem? i need to take it all apart and have 3 pieces... there's an L bracket in the corner, but i'm pretty sure the installers put it on as one piece
thoughts?
