My stove was scheduled to be installed this Friday. I e-mailed the installer the following e-mail, and then he called and said that he really appreciates and was impressed that I have done so much homework, and at this point, he felt I could install it myself. He was very nice and polite about it. He said he had good relationships with his customers and did not want any problems. He said he would get me the Kaowool if I needed it and even answer questions, if I needed information concerning another persons, install. He basically said, in so many words, I knew too much, asked to many questions and I made him uneasy. I think he was worried I was going to be too picky. the guy was really nice and I am disappointed that he would not work with me. I have had $1200 bids, $2200 bids and $3400 bids. All with different liners and opinions on how it should be done.
Following is the cut and pasted e-mail, as sent.............
(Name); thanks for the estimate and also, answering all my questions. I do look forward to you beginning the job.
I came home to look at my list, and I do have a few more questions; as follows……..
1) Clarification as to “all stainless steel” as in your bid… the website that you had me go to, states galvanized outer layer. So is this "all stainless steel" or not?
2) I am going to pick up some mineral insulation, kaowool, or Roxul. All of them not combustible and used for a “soft block off plate above heatilator holes (to capture some of the insert heat, and above damper. Also use some to put under the top plate/storm collar, and to lay a layer behind the stove like the ceramic blanket to keep heat transfer from the back. I am hoping to find some locally or have it shipped priority mail, to have it before you get here. Is this going to be a problem? As far as labor goes, we are only going to stuff some above the damper, stuff some under top collar and lay a blanket on back of fireplace before insert goes in. I don’t think it will be any big deal. Are you ok, with this?
3) Is the flashing, storm collar, screws, cap and parts, all stainless steel?
4) While you are on the roof, can you take a flash light and look down second flue and just see if there are any nests, dead animals or tons of creosote, in the flue you are not using?
5) Can you describe your warranty for your work? Including if stove gets damaged………
6) Can you tell me how it works if a liner fails? Who replaces it and do I pay to have another install, to get it put in, if under the 25 years?
7) How do you seal the top plate, with RTV 600 degree silicone or what?
Thanks again. I look forward to your response and also working with you.
Kim
Kim
If I would of waited till he was here, on Friday...........my fear was he wouldn't insulate, wouldn't provide me with warranty information and I would be stuck. Thanks for the input. I think it sucks that I am paying over $5000 for a job and I can't seem to find anyone that is willing to 1) put a Simpson double insulated liner, with a soft or hard block off plate, insulated top plate and insulation behind the insert. Doesn't seem to much to ask. I have even said I will get all the supplies, liner, etc., if they don't typically use a Simpson products and they can just install............. they flat out have told me they mark up the liner and make several hundred dollars off the liner, so no go, either. If I could lift $500 lbs of stove, I would at this point, try it myself.................. I am about over this................. I only keep going cuz I want my stove in...........
