Installing lights on siding
lumbajac Posted By lumbajac, Oct 22, 2008 at 11:15 PM
Thread Status:
  1. lumbajac
    lumbajac
    Member 2.
    NULL
    Mar 15, 2008
    85
    0
    Loc:
    Upper Peninsula, Michigan
    Anyone have experience installing wall lights on LP Smartlap siding, beveled wood siding, or cement board siding? I have sided my new home with LP Smartlap and am wondering now how to install the lights over the siding without cutting in 4" holes for round electrical boxes. I would like to use the low profile "pancake" round electrical box mounted directly to the siding. However, with the lap, there is a slight pitch to the siding which I fear may make the light look noticeably out of plumb.
  2. imiller1974
    imiller1974
    Member 2.
    NULL
    Jan 23, 2008
    35
    0
    Loc:
    lancaster, sc
    Check out hammerzone.com. I really like that site, it may give you a few ideas...
  3. lumbajac
    lumbajac
    Member 2.
    NULL
    Mar 15, 2008
    85
    0
    Loc:
    Excellent site that I'll probably use in the future... but nothing on what I'm working on. Thanks.
  4. junksta
    junksta
    New Member 2.
    NULL
    Oct 13, 2006
    44
    0
    Loc:
    Pinedale, AZ Elev. 6400'
    If it's beveled siding, and you can get a spare piece of it, cut out a small piece and reverse the angle to get you back to even. Straight hardiplank may require you to fabricate a little piece to get your angle just right.
  5. lumbajac
    lumbajac
    Member 2.
    NULL
    Mar 15, 2008
    85
    0
    Loc:
    Its single thickness lp smartside. I've been considering making my own beveled block using a piece of Azek plastic board... possibly running across a jointer with the bed beveled accordingly.
  6. Cluttermagnet
    Cluttermagnet
    Minister of Fire 2.
    NULL
    Jun 23, 2008
    901
    54
    Loc:
    Mid Atlantic
    They sell special injection molded foam lamp blocks that fit overlapping siding such as the vinyl and aluminum stuff you often see. But such a block could also be used to level an outlet box for flood lamps. Look in Home Depot, Lowes, etc. They are octagonal in shape and about 7x7 in or so. You will see a zig zag shape in the back, viewed across either side edge. Pretty cheap, too- only a few dollars for these, if I remember right. Shims are actually the harder way to do this. You just fit them over the 'nose' made by the lower edge of a course of siding, spanning it onto the next, lower course of siding. Or is your siding type just dead flat?
Thread Status:
